Wire Harvester Box Using Corrugated Box
Introduction: Wire Harvester Box Using Corrugated Box
We DIYers use bread board to test small circuits or sometime we even make wire wrap board for larger circuit. what about thoes wire that are of no use. My Idea is of reusing thoes waste wire by harvesting them rather then throwing away
Step 1: Materials Needed
1) corrugated box
2) nut and bolts
1) Paper glue
2) Drill bit
3) scale
4) knife
Step 2: Get a Corrugated Box of Atleast Dimention 40 X 30 X 11 Cm
get a corrugated box of atleast dimention 40 X 30 X 11 cm dimention or above.
Step 3: Cut the Smaller Edge to Get Two Edge Plate As Shown Above
cut the smaller edge plate that has length of 30 cm from both the side to get two edge plate
Step 4: Follow the Above Step for the Other Side Also As Shown in the Figure
follow the above step for the backside also to get two more edge plates.
Step 5: Connect the Corner Plate of the One Side of Corrugated Box From Inside Using Cellotape
connect the corner plate of the corrugated box from inside using cello tape of one side as shown in figure
Step 6: Connect the Conner Plate of Same Side From Out Side As Shown Above
connect the corner plate of the same side using cellotape from out side
Step 7: In This Step the 4 Card Boad Plate That Was Created Need to Be Cutted in the Dimetion to Fix Inside the Box
cut the four car board plate of dimention 28 X 10 cm so that it can fixed inside the box without any force
Step 8: Glue the 3 Plate Using Paper Glue
In this step divide the inner space in foure equal haves and then glue the cardboard plate as a divider as shown above
Step 9: Drill 4 Hole From the Corner That Connects the Divided Space
drill each holes for each divided space larger enough that a wire can drop in with out any force
Step 10: Make 4 Latch Plate Using Remaing Cardboard Plate
in this step you need to make 4 latch plate using the one cardboard plate left
Step 11: Connect the Latch Plate Using Nut and Bolt As Shown Above
connect the latch plate using screw and bolt easy enough to move so that the box can be close using latch plate
Step 12: Connect 4 Sticker of Different Colour It Should Be the Colour of the Wire That You Want to Feed in the Space
connect 4 sticker of different colour of the wire that you want to feed in the space
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
