Wire Holder
Introduction: Wire Holder
Need a place to hold your spools of wire? Tired of the spools rolling off your desk? Here you go, and if you need to, you can use it as a paper towel holder...
Step 1: Parts
4 small-medium screws.
13" of 3/4" dowel
1" x 4" wood.
Step 2: Measure
Here you can lay out your spools of wire and just go or follow these plans.
bottom is 4 1/8" long
measure up 1" from the base,
measure 1 3/4" from the side,
connect those two points with a 45 degree angle.
For the holes for your dowels measure:
top hole - 1 1/4" in, 3/4" down.
bottom hole - 1 1/8" up, 3/4" in from the side
Step 3:
heres a shot of it with the holes drilled, use a 3/4" bit.
Step 4:
Counter sink one hole for your both of your screws, this will hold the dowels in place and let you replace the spools when they are empty.
Step 5:
Cut the dowel in to 6 1/4" lengths.
Step 6:
Put it all together and you are done.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    I have the same spools, they are pretty stiff wire. Good project in its simplicity.
