http://www.machinescience.org/catalog
Remove these ads by
Signing UpStep 1Simple Circuit Games Unit 1: Wire Loop Game
In this project, you will build your own wire loop game, using wires and batteries. In your game, players won't receive shocks if they lose. Instead, a buzzer will signal whenever the metal loop touches the curved wire. The wire loop game has two challenges. In Challenge 1, you will learn how electricity from a battery can be used to make sounds. In Challenge 2, you will build your own wire loop game and then play it.
I recomend using a resistor (the right ones will usually come with the LED) before the led and putting the speaker first so that the resistor dosn't mess with the sound. remember, current flows from negative to positive
Sorry if i went into too much detail, after having to prove to my friend that there is no "Any" key on a keyboard i've started to lose faith in people
The issue is having to ground the person you're shocking vs using the human's ability to leak charge and act as an effective enough ground.
your taser has 2 terminals right? i'm talking enough voltage to tase somebody with only 1 terminal.
read about it here: http://www.instructables.com/id/SP6MCPCF6B7T1OG/
