Wire Ornaments on the Cheap
Published
Introduction: Wire Ornaments on the Cheap
About: I am fifteen, attending an early college high school. I have aquired many interests over the years such as metal work, 3D printing, arduino, circuitry, and other forms of trade via self teaching. I work alon...
This Instructable will show you how to make small wire ornaments for cheap.
Materials:
Mechanics wire ($1.00)
Soldering iron ($5.00)
Solder (2.00)
Magnets. (Free!)
Step 1: Template
Making a template will help with bending your wire to the appropriate size according to the drawing. Drawing on graph paper works best but you can use anything.
Step 2: Bending
The next step is to cut and bend your mechanics wire to the template you just made. I found it easier to bend the curves by hand and use pliers for more square bends.
Step 3: Magnets
I cannot stress how important the magnets are, use as many as you have when you are getting ready to connect them. If you are interested in this method of making wire ornaments go out and buy a welding magnet with a flat surface to place your wire for maximum security.
Step 4: Soldering It All Together
Once you have temporarily secured your work with magnets it's time to solder. I used a regular soldering iron with regular solder and it seemed to work the best. TIP: if you keep melting the solder of another nearby piece just tin the wire that you are trying to attach to avoid over heating the wire, this works since heat is conducted easier through a liquid this slows down the time needed to heat the wire.
Step 5: You're All Done
Once you have finished you can paint your ornament or add a hook and hang it from somewhere, have fun, be safe, and enjoy!
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
