loading
Picture of Wire Snowflake
In this instructable I will show you how I re-purposed some computer wire to crochet a snowflake.  I disassembled an old keyboard a while ago to use for another project. I was happy to be able to put to use the remaining part of that old thing to make a pretty Christmas ornament.  If you don't have an old keyboard to disassemble you can find the wire in other computer cables or from  broken headphone/earphone.
Step 1: What you will need
Picture of What you will need
  • Old computer cables or headphone wires etc.
  • Beads
  • Pliers
  • Crochet hook
Step 2: Stripping the cable
Picture of Stripping the cable
I had some cable left over from an old keyboard that I took apart for another project.  Inside the cable I had four wires plus another which didn't have a plastic covering, this consisted of a bundle of 10 thin wires.  I separated the thin wires into bundles of three and used that to crochet my snowflake.  To connect the wires to make it longer just twist the ends together.
Step 3: First round
Picture of First round
  • Make a slip knot to start crocheting, I left a bit of a tail so I can add a bead later
  • Ch 4
  • Sl st into first chain
  • Ch 4, add a bead, ch 5
  • *Dc into ring, ch 3 and add bead
  • Ch 3, dc into ring
  • Repeat 3 times from *
  • Ch 3, add bead and dc in the ch 9 (ch4 +5)
You should now have 6 petals with beads at the tips
Step 4: Second round
Picture of Second round
  • *Sc to dc post, ch 9, add bead ch1, dc in chain before bead, ch 7, sc around same dc post
  • Ch4, add bead, ch 4, sl st into chain with bead on next petal from round 1
  • Ch4, add bead, ch 4, sc in dc post
  • Repeat from *
  • Tie off
Add a bead in the centre of the snowflake using the tail left from the slip knot make at the start. Add some string to hang your snowflake.
Very nice. I am making something similar for the advent calendar.
ChrysN (author)  blinkyblinky3 years ago
Cool, I guess we'll have to wait until the 23rd to see it.
On the 23rd I will have some code written for the Arduino...
Can you program?
Sadly no, but one day I hope to try my hand at working with Arduino.
I guess the snowflake idea didn't work...
The star is pretty cool, it would make a nice Christmas tree topper.
Thanks.
bajablue3 years ago
Pretty and SO CREATIVE!
ChrysN (author)  bajablue3 years ago
Thanks!
That is awesome! I'm a beginning crocheter, how much skill does it take to crochet with wire?
ChrysN (author)  Penolopy Bulnick3 years ago
It's not much different than using yarn. With the thickness of wire I used it is still quite pliable, with thicker wire it is more rigid and harder to work with. The only trouble I had was if I made a mistake and try to undo stitches the wire tends to kink.
susanrm3 years ago
Pretty! You're reminding me of some old wire jewelry I used to make... hmmm...
