loading
loading
Picture of Wire Tree Sculpture
A very good present for Christmas!
Step 1: Wire
Picture of Wire
4 little wires with insulation.
Step 2: Stripping
Picture of Stripping
strip insulation of all 4 wires and the insulation on the 4 little wires
Step 3: Cut in half
Picture of Cut in half
Cut stripped wire in half and then cut in half again so you have 4 wires of the same length.
Step 4: Twisting
Twist two wires together leaving some of the wire untwisted at the top and bottom.
Twist 2 at a time then once all wires are paired up do it again with another one until you don't have any more loose wire left.
Step 5: Add the V
Remember trees aren't perfect and usually have v's or something.
Redo step 2 except not as long and as much twist them as usual and then twist around tree and have it stick outwards.
Do that again but wrap around v spot so it looks more realistic (look at pictures)
Step 6: Your Done
Picture of Your Done
Tweak it a bit to get it just right.
bobzjr3 years ago
Very nice work here. I could see focusing on the typical "above ground" portion of the tree - and placing inside of a deep shadow box arrangement.
Blechmen (author)  bobzjr3 years ago
That is an awesome idea please if you do make it post pictures thanks.
kruggles3 years ago
if you use a larger gauge wire to begin with, the base of the tree will be a lot thicker and sturdier. my dad made me one awhile back using a really thick copper electrical wire he had left over and it was easy to bend into place but since even the copper wires inside were thick it wouldnt easily bend out of place if it was moved or dropped. i love this idea and i plan on making another one when i get the chance.
bobzjr kruggles3 years ago
Good idea with the thicker wire - I may try this out myself...
Blechmen (author)  kruggles3 years ago
LOl yea thanks
dude this is wicked cool .. im def. inspired .. =)
Blechmen (author)  shaylynnelise3 years ago
Thank you so much for your nice comment and don't forget to vote on the contest.
