Introduction: Wire Tree Sculpture
This will show you how to make a beautiful work of art in less than an hour. Almost free to make, this is a great gift idea, or make one for your self.
Step 1: What You Will Need
All of these Items are either really cheap, or FREE!!!
Wire (I used steel wire I found the other day, but any bare wire works)
Needlenose Pliers
Optional Items
Base to mount on (I used a rock)
Gloves (recommended on heavier guage wire)
Decorations (and adhesive of some kind if needed)
Step 2: Cut the Wire
You want your wire to be at least 8 inches long, that way you have room to twist and bend later. I did it about 14 inches long, I wanted a larger tree.
Step 3: Keep Cutting!
You will need quite a few pieces of wire. It's actualy a good thing if they are varying in length a little. Just eyeball it as you go, using a previous piece as a judge in length. You're not going for perfection here, I think that's part of why this is so fun.
Step 4: Group and Start to Form
Well, I'm out of wire, so I guess I'm done... I got 21 pieces cut from that ball, not bad. For thicker wire, gloves gome in handy for this. grab the wire up in a bunch and literally twist the center a few times. You will get an uneven spiral. This will be the trunk of the tree.
Step 5: Forming the Branches
after you have the tree twisted in the center. start splitting up the wires. it's easiest to split into 2 large branches but you can literally do it however you want to. Take your groupings of wire and twist them in a similar fashion to what you did for the trunk.
Step 6: Keep Splitting and Twisting
Just like you did on the main branches, split up the wires and twist those groupings. As the groups get smaller, you will start to see a bare tree form emerge. Split and twist until You have single wire branches in the different directions. Bend your branches in different directions to fill out the desired shape.
Step 7: Got the Top Half, Now What?
Now it's time to shape the roots. Not much to it, just apply the same method from the top to the bottom half. Flatten out your roots with your hands or your pliers. At this point, your tree is done. All that is left is a little customization.
Step 8: Presentation
For this specific tree, I used a flat bottomed rock (I think it's granite) from the courtyard of my apartment. All I did was set the tree on the rock, took my pliers and bent the roots around it. I curled them on the bottom so the tree wouldnt scratch whatever furiture it ends up on. I've also used flower pots with sand, bonsai stands, it doesn't really matter. Pick something that you ant to use and go with it.
Step 9: Finishing Touches
This tree still felt like it needed something else. I happened to Have a red piece of foil paper from a pack of cigarettes my friend left at my place, so I quickly folded an origami crane and glued it to a branch. You can decorate it however you like. Some Ideas are beads, buttons, soda tabs, even hang your jewelry on it. There you have it. A Metal sculptre that is all your own. Snazzy.
