3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wire Tree Sculpture
Wire Tree Sculpture
  • C:\Users\Pai\Pictures\2007-10-14 instructables wire tree of life\instructables wire tree of life step 10a.JPG
  • C:\Users\Pai\Pictures\2007-10-14 instructables wire tree of life\instructables wire tree of life step 10.JPG
  • C:\Users\Pai\Pictures\2007-10-14 instructables wire tree of life\instructables wire tree of life step 10b.JPG
This will show you how to make a beautiful work of art in less than an hour. Almost free to make, this is a great gift idea, or make one for your self.
Step 1What You Will Need
What You Will Need
  • C:\Users\Pai\Pictures\2007-10-14 instructables wire tree of life\instructables wire tree of life what you need.JPG
  • C:\Users\Pai\Pictures\2007-10-14 instructables wire tree of life\instructables wire tree of life step 9.JPG
  • C:\Users\Pai\Pictures\2007-10-14 instructables wire tree of life\instructables wire tree of life what you need a.JPG
  • C:\Users\Pai\Pictures\2007-10-14 instructables wire tree of life\instructables wire tree of life what you need b.JPG
All of these Items are either really cheap, or FREE!!!
Wire (I used steel wire I found the other day, but any bare wire works)
Needlenose Pliers
Optional Items
Base to mount on (I used a rock)
Gloves (recommended on heavier guage wire)
Decorations (and adhesive of some kind if needed)
23 comments
Apr 22, 2012. 12:10 AMfolklife says:
I used scrap copper stranded wire- removed the rubber covering, and started twisting like you said. I also soldered some sections to hold in place. Fab idea!
Dec 21, 2010. 4:56 PMSunshineGrl says:
Do u think itd look as fabulous in copper wire?
Jul 10, 2009. 8:18 PMandi456 says:
My grandpa made one of these, but he polished amethyst and glued it to the branches as leaves. It is very cool.
Apr 28, 2009. 2:05 AMdoubletake says:
Do you think this would work using wire hangers?
Dec 16, 2008. 2:12 PMshelbabyrn says:
What is the best gauge wire to use and any suggestions on where to find colored craft wire?
Dec 21, 2008. 2:27 PMbombmaker2 says:
paint it your self
Dec 25, 2008. 4:43 AMbombmaker2 says:
yup
Nov 21, 2008. 3:11 AMKJS says:
Great instructable :) I think I'm gonna make it with wires with same widths, but different colors(Goldish, silverish and one that changes colors a bit like gasoline in water, only darker)
Nov 9, 2008. 8:31 AMsoullight says:
I am new to this hoby and was wondering if any one knows where I can buy 1mm un-holed gem chips.
Jun 10, 2008. 5:36 PMchinasmom2000 says:
poi_pai, this looks SO cool!! What a great instructable! I wonder if you could use different gauges of wire in the same tree to get more detail; smaller branches, twigs, etc. I love this and will try it; it looks great!
Oct 15, 2007. 4:58 PMMisterSlippy says:
Nice instructable :-)
I use this method for the structure of my sculptures, which I then build up with plaster and paper mache. Here's a little vid of one of mine ;-)
http://www.youtube.com/watch?v=QriDlQgsDnw
Oct 15, 2007. 3:31 PMguyfrom7up says:
I started working on a project similar to this ( I started about a week ago, so it should still be original) except I take it like 5 steps furthur
Oct 14, 2007. 7:14 PMspool says:
If you use copper wire and coat it with liquid latex you get this really cool wood look. The latex reacts with the copper and it turns brown. I used to make trees like this for architectural models. From there you can get some fake foliage. It comes in a bunch of shades of green and brown. Its kind of a powdery lightweight foam. You can probably get it an a craft or scale model store. Anyway, just coat the branches in a glue that dries clear and roll it around in the foliage. Then build up coats of it with different colors. I've made hundreds of them at a time, although they were much smaller than the one in this instructable. You make up all the wire, mount them to a block of foam and dip them all at once in the latex. Then build up coats. Same thing with the leaves.
Oct 14, 2007. 7:29 PMspool says:
yes like special effects make-up latex
Oct 14, 2007. 5:11 PMJohn Smith says:
That looks pretty cool. If you used solid core insulated wire (or even magnet wire) you could wire it up, using mini LEDs for fruit, and stuff.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:poi_pai
