Wire Wrapped Guitar Pick Necklace
1,981
28
Posted in PlayGuitars
Introduction: Wire Wrapped Guitar Pick Necklace
So I play guitar and i thought it would be fun if I made a piece of jewelry or a holder for my picks. This is what I came up with.
Step 1: What You'll Need.
Pliers
Needle nose pliers with a cutter
Strong glue
Some material (such as leather) to put around your neck
Split rings or bail ( optional)
Wire
Scissors
Pencil
Guitar pick or other item you want to wrap
Paper to draw on
Step 2: Trace and Design
So Take your pick and trace it. Then draw the design you want to reference to. This design actually didn't turn out say all like how I drew but it did look better.
Step 3: Cutting and Shaping
Cut the wire to the necessary length,(you might want to go over the necessary length just in case) I used two wires and connected them in the front and back. Make sure you shape the wire around the pick other wise it might not turn out the right size or shape. You won't really need your regular pair of pliers you can just use them to hold down the wire while you shape it instead of using just your hands.
Step 4: Making It a Necklace
Now take your leather and cut it to the right length and add the clasp. Some clasps need glue. ( if you're using a split ring or bail, slip that on before the clasp). Now a attach the wire to the necklace or split ring. This might take a while but this is how I did it. If that doesn't work just glue it to the necklace. And your done! Please feel free to comment and subscribe. And if you want to see another version of this then check out pick holder pendant: by eldatote. He beat me to making this instructable. Thanks!
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Thanks Penelope Bulnick! :)
