Wire Wrapped Patterns on How to Make Wire Flower Earrings With Red Crystal
1,586
63
Published
Introduction: Wire Wrapped Patterns on How to Make Wire Flower Earrings With Red Crystal
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Here, I want to share you a jewelry making tutorial about how to make wire flower earrings. A fab pair of flower shaped earrings is waiting for you!
Step 1: Materials Needed in Wire Wrapped Flower Shaped Earrings Tutorial:
4MM Normal Glass Beads
0.5MM Copper Wire
Brass Chains
Headpins
Earring Hooks
Step 2: Make the Wire Wrapped Flower Tutorial
1st, cut off about 20cm copper wire, and then follow the specific diagrams to bend the wire to form a 5-petal flower shape;
2nd, fix the end by wrapping wires around the center of the wire wrapped flower;
Step 3:
3rd, slide a 4mm glass bead to one wire, and then fix it to the wire wrapped flower by wrapping the wires; 4th, cut off the extra wires and pinch the end, so that it will not prick you.
Step 4: Make the Dangles for the Wire Wrapped Flower Shaped Earrings Tutorial
1st, use a 4mm glass bead and a headpin to make a bead dangle;
2nd, make another three bead dangles in the same method;
Step 5:
3rd, cut off a 5-link chain, attach the wire wrapped flower to chain;
4th, attach the four bead dangles to the chain as picture shows;
Step 6: Attach an Earring Hook to the Top of the Chain to Finish the Flower Shaped Earrings.
Step 7: Here Is the Final Look of the Wire Wrapped Flower Earrings Tutorial:
Tada! This tutorial on how to make wire flower earrings is done! There is so much fun in wire wrapping working. This pair of flower shaped earrings is a great design, isn't it? Look forward to your wire wrapped flower tutorials! Just to do it!
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    3 Comments
    Thank you~:)
