This is the second case i have made. i am going to teach you how to mod your old computer case into a stereo and wire a car stereo to a computer PSU.
Tools:
-wire cutters/strippers. (or just use a knife like how i did)
-needle nose pliers
-solder-less butt connectors (unless you plan to solder your wires)
-Computer PSU
-computer tower (or any other metal case)
-car stereo
-dremel or similar
-tape measure
-pop rivet gun
-paint
-time
-a speaker terminal
-a drill
optional:
lights, plexiglass, etc.
it would be nice to have a jigsaw, like this- http://www.sears.com/shc/s/p_10153_12605_00917235000P , so i can make an instructable for a speaker box
Remove these ads by
Signing UpStep 1Know your wiring
yellow____12v
red______5v
orange___3.3v
Black____ground
Wiring from stereo:
Red_____ign sitch
yellow___constant 12v
black____ground
VERY IMPORTANT!!!!!!! In order for your psu to work when not connected to the mother board, the green wire MUST be connected to any ground wire.
if you wish to add a switch to the PSU so you dont have to unplug it all the time,
-carefully take apart the psu.
-be careful not to touch the capacitors.
-cut the blue wire (positive), strip it, and add a butt connector to each end of the blue wire.
-then connect enough wire to extend to the switch (depending on where you put it).
-connect the wire to the switch. i used hot glue to keep the wires from touching each other on the switch.
MAKE SURE YOUR MAIN POWER CABLE IS UNPLUGGED. i flipped the breaker when adding in the switch.
but also, one of the problems is that if the radio volume turns up too high, the PSU cuts power to prevent an overload. i wouldnt want that happening while browsing the web.
one optional way to fix that is a bigger PSU,
Take care mate.
Kevan
thanks,
kevin
also, i didnt solder for 2 reasons.
1. i was inside while wiring this. it was about 100 degrees farenheit in my garage.
2. i wanted to be able to just cut the wires and reconnect if needed.
Alright, its your project, I was just saying soldering is the best way, but I guess it doesn't really matter.
