I love dragons and I love making things. I want to share how to make a metal dragon pendant with NO soldering, casting or hot work.
You will need:
Tools:
round nose pliers
chain nose or needle nose pliers (if they have ridges on the jaws, cover with masking tape to avoid marring the wire)
wire cutter or flush cutter
Awl or small, sharp nail or heavy t-pin
craft scissors (don't use your good sewing scissors because you will be cutting the metal foil - bad for quality scissors)
sand paper - 180 or 220 grit or emory board for finger nails
2 seed beeds - about 2 mm diameter, size 10/0 (for eyes)
20 gauge wire - copper, brass, silver etc.
26 or 28 gauge wire (you can use up to 24 gauge but it is much harder get neat results)
heavy metal foil or thin sheet metal - 4 oz. copper foil, 36-38 gauge tooling foil, such as this http://www.dickblick.com/products/pure-metal-tooling-foil/ or use metal from clean soda pop cans.
optional: 32 gauge wire
Remove these ads by
Signing UpStep 1Cut out the wings
1. Fold wing pattern in half (or design just one wing).
2. Measure or eyeball the width and fold one edge of the metal sheet over a little wider than the wing width.
3. Place the shoulder side of the wing on the folded edge of the foil. Secure pattern with tape or trace wing with a fine permanent marker (whatever kind can mark on metal).
***** CAUTION: Metal foil can be sharp and give you a nasty 'paper-cut'. Handle with care! Hold the metal by the flat sides, not the sharp edges *****
4. Carefully cut around the outside of the wing pattern. DO NOT cut the folded edge, leave the wings attached on the shoulder side so they can be wired to the body.
5. Lightly sand the sharp edges of the cut foil, just enough to remove the sharp bits.
Totally voted for you, good luck!
