Wireless AVR Programmer (WiFi)
8,182
19
35
Posted in TechnologyArduino
Introduction: Wireless AVR Programmer (WiFi)
About: Electronics and Telecommunication Engineer, Software Engineer, Hobbyist
This wireless programmer provides an AVR ISP programmer over Wi-Fi network.
You can either have it connected to your WiFi router/access point or open an Access Point in the programmer itself and connect to it directly.
Hardware Materials:
1x -- ESP8266 (ESP-12E/F module) -- Rs.250 ($3-4 appx)
1x -- 5v SMPS (12v would also do) -- Rs.50 ($1 appx)
7x -- Jumper / Hookup wire -- Rs.35 (50cents appx)
1x 1117 3.3v regulator (if 5v is used for Atmega)
Note: Follow schematic for circuit for programmer.
Software Material:
WiFi_AVRISP
ESP_ConfigStorage (library)
Note: Download the master folder into your Arduino sketchbook folder. Install ESP_ConfigStorage to your default library folder or copy all files to downloaded WiFi_AVRISP folder.
Tools:
PC (With Java and Arduino software installed along with ESP8266 hadware and tools)
USB to TTL converter (CP2102/FTDI232 etc)
USB cable for connecting PC to USB-TTL
Connecting wire for USB-TTL to ESP-12E
Note: If you have Nodemcu or something similar, you might not need this extra cables.
Step 1: Install Netburner Virtual COMM Port Driver
Install netburner com port driver software from Netburner site.
Steps:
http://www.netburner.com/ -> Products -> Netburner Software, Protocols & Tools Suite -> Deployment Tools -> Download Virtual COMM Port Driver
Install the software as usual.
Step 2: Uploading the AVR_ISP Program to ESP8266
  1. First confirm your USB-TTL port in device manager.
  2. Then open Arduino IDE and WiFi_AVRISP program in it.
    Note: You must have ESP8266 boards installed first. If not do so now.
  3. Select NodeMcu 1.0 (ESP-12E) in boards menu.
  4. Set Flash size to 4M (1M SPIFFS), 4M (3M SPIFFS) will also do.
  5. Port to USB-TTL port.
  6. Upload the program.
  7. Upload data folder.
Step 3: Connect to ESP8266
Connect to ESP8266 module.
It can have any name based on module or previous configurations. But it should be open by default.
I used a phone, any WiFi enabled device should do.
Step 4: Configure ESP8266
Configure ESP8266 WiFi configuration.
You can make it connect to your Access Point (I used TPLINK WR841ND router), or open an access point inside it.
Step 5: Configure Netburner Virtual COMM Driver
User your preconfigured IP or check router for IP allocated.
I used reserved IP address in router.
Step 6: Program Atmega Using AVRISP
Connect your Atmega chip in ISP connection to your newly made WiFi_AVRISP device.
Upload program using programmer option.
Note: First upload after power up will miss first 3-4 sync, but will upload finally. Net uploads will have no such hiccups.
( Donate )
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    35 Comments
    No, I want to know this micro (Atmega 328) has arduino bootloader ?
    hi does it need arduino bootloader for atmega328 p?
    Not necessary. You can directly upload the HEX or use any AVR Programmer.
    i've try the tutorial with nodemcu and arduino, and i can connected nodeMCU with the laptop but when i upload the program (step 6), i got error like :
    avrdude: stk500_recv(): programmer is not responding
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
    attempt 10 of 10: not in sync: resp=0x03
    could you help me ?
    thanks before :)
    Did you follow the steps exactly?
    Please provide the connection you are using. Picture or video.
    please help!!, where I can change SSID and Password ,, thanks in advance
    SSID of what?
    If you are asking for changing SSID of ESP, then check Step 4.
    I mean that after uploading avrisp and data folder, I can't access the esp through IP .
    I can't complete Step 4 :(
    Please describe step by step the procudure you followed.
    So you connect to esp directly?
    But after that when you open ip addess 192.168.4.1 in your phone/pc it dosen't open?
    How did you connect to ESP?
    Did you connect to it using built-in AP?
    May I contact you by email ? :) :)
    Thank you for your help
    I would prefer to use this chat, as it would also help others while troubleshooting.
    You can always PM me for personal queries.
    Nice work:
    I tried to compile and have an error because Arduino Ide not find ESP_ConfigStorage library.
    I searched the web and find nothing. I have properly installed all libraries for ESP8266 and have already updated several sketcks for nodemcu ESP12E.
    Please can you tell me where to find this library?.
    Thank you.
    Use:
    https://github.com/Subhajitdas298/ESP_ConfigStorage
    Many Thanks
    I have updated the instructable with library link directly.
