A word of warning though... this one's a monster!!
Background
So a few weeks ago, my usual speedometer for my bike gave up and eventually stopped working completely. I have had it for a good number of years now and it has served me well, but it was obviously time for a replacement. This got me thinking and inspired me to create this Arduino based project. A while ago, I published an instructable documenting how to build a 'Wireless Altoids Display'. It consisted of an 16x2 LCD controlled by an Arduino and a pair of maxsteam Xbee modules. Simple enough, ASCII text sent over serial from the computer would be displayed on the remote LCD. Through this project, I will hopefully be able to show you how you can integrate that setup in a useful application.
What does it do exactly?
The 16x2 display is mounted on the bike's handle bars and provides the user with feedback in terms of how fast they are currently traveling. There is also a nice little bar graph on the top row to provide a visual representation. As well as being able to view your speed in realtime on the bike, the data is also sent wirelessly 'back to base' where the results can be logged and visualised on an moving graph using 'Processing'. The arduino sends the current Speed, Average and Distance covered whilst riding.
Components & Configuration
>> On the bike: (Arduino + Magnetic Reed Switch + Xbee Pro Module + 16x2 LCD)
>> At home: (Xbee Pro Module + FTDI USB Cable)
Let's get to it!
Remove these ads by
Signing UpStep 1Tools & Components
Components:
- (2x) ALTOIDS Tins
- Arduino ATMega 328
- 16x2 LCD HD44780
- A form of sheet insulation (Card / Foam etc.)
- 5mm Clear PVC Tubing
- (2x) Xbee Pro Modules (U.FL antenna connector)
- (2x) U.FL to RP-SMA pigtails
- (2x) Adafruit Industries Xbee Adapter Kit
- (2x) RP-SMA 2.4Ghz Duck Antenna
- USB type A to type B
- USB to Serial FTDI
- Cat5 Cable
- 1k Resistor
- Soldering Iron & Solder
- Needle-nose Pliers
- Scissors
- Marker Pen
- Wire Strippers
- Fine Grade Sandpaper
- Power Drill (5mm bit) / Bodkin Skewer
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=310376577132#ht_1286wt_952
mark out the LCD then get a dremel and cut the box, it will look much better and would be less affected by water
http://www.sgbotic.com/index.php?dispatch=products.view&product_id=1080
one more thing,is it possible of i left out part where the antenna has to be installed?is it necessary to have antenna?
thank you. :)
Great job.
I can't seem to link to the sketch, I am trying a similar project and am a bit lost...
Thanks
You can see the original, full size image here...
Hope this is okay? :)
How does the unprotected display stand up to the elements?
http://cadjunkie.com/1489/blog_simple-graphic-trainer/
All the links should work fine now or you could go straight to the arduino code here!
Hope this helps??
