Using an Altoids tin was inspired by the need to have a small yet protective enclosure for a pair of Xbee modules recently bought from Sparkfun. I purchased the Xbee Pro modules with external antenna for the extended range the setup provides (useful for future projects). Then I realised I would need to mount the antenna socket and have a box to house the circuits.
A L T O I D S !
Overall Configuration
There will be a 'remote' Altoids tin containing Arduino, LCD and Xbee module.
A second Altoids tin containing an Xbee module only. This connects to the PC with a USB to FTDI serial cable.
Data is sent from the PC using a terminal program such as the Arduino 'Serial Monitor' and appears on the Altoids display.
So here are some possible ideas for use with this setup:
(Data flow PC to Wireless Display)
- Email Notifier
- RSS Feeds
- Facebook/Twitter Updates
- Realtime Clock
(Data flow Wireless Display to PC)
- Weather Station
- Speedometer
- Engine Monitoring
- Heart Rate Monitor
- Other realtime data logging
Let's get started!
Remove these ads by
Signing UpStep 1Components & Tools
A) Featured P2P Wireless Setup
- (2x) ALTOIDS TIN
- (1x) Arduino Duemilanove
- (1x) 2x16 LCD HD44780
- (4x) Hex Posts/Spacers
- (4x) Matching Screws
- Form of sheet insulation (Card / Foam etc.)
- (2x) Xbee Modules (U.FL antenna connector)
- (2x) U.FL to RP-SMA cable connector
- (2x) Adafruit Industries Xbee Adapter Kit
- (2x) RP-SMA 2.4Ghz Duck Antenna
- (1x) USB type A to type B
- (1x) USB to serial FTDI
- Cat5 Cable
I realise that the Xbee modules can be quite costly.
If you still want wireless and you're content with one-way communication then there are alternative radio modules such as these from HopeRF:
http://shop.jeelabs.com/products/rfm12b
I think it's worth mentioning that this project can still be effective without wireless communication so why not create a neat USB desktop widget?
B) USB Version Only
If you just want to create a USB Altoids Message Display you're going to need:
- (1x) ALTOIDS TIN
- (4x) Hex Posts
- (4x) Matching screws
- Cat5 Cable
Tools Needed
- Soldering iron & solder
- Needle-nose pliers
- Scissors
- Tin snips
- Marker pen
- Wire strippers
- Cross head screwdriver
- Fine grade sandpaper
- Drill & bits 3mm + 6.5mm
Nice work :)
http://www.youtube.com/watch?v=XGGvrkku1ig
is it same between u.fl with chip?? i'm new in xbee. so really need your help.thanks
I have a feeling that putting the antenna inside a metal box is going to shield and discharge the radio signal - a bit like a Faraday Cage?? Although i'm not certain.
You could always try it I guess - if it doesn't work, how about mounting the Xbee on top of the Altoids tin instead of on the inside?
Let me know how you get on :)
I could be way off though as I wouldn't know where to buy the parts from the UK alone.
I think it's the Arduino and radio modules that bump up the cost...
Check out the link below for a great kit that was designed especially for low cost Arduino/radio communication!
http://shop.jeelabs.com/products/jeenode
Hope this helps?
The modules used here are XbeePro 60mW which are good for about 1 mile outdoors, but believe you can get higher power output modules with 6 mile range. I haven't done a range test yet but if you disconnect one module and power it up again, data starts streaming almost immediately!
Please keep me informed about your project, it sounds very interesting :)Check out this link... (google mail though)
http://blog.tinyenormous.com/2008/11/25/gmail-notifier-project-for-dummies/
Sorry I don't know exactly but hope this helps?
