3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wireless Altoids Display
Step 10Upload Sketches & Testing
Here are some simple sketches.
I suggest that you upload them directly over USB cable to the Arduino. Although I believe it is possible to upload wirelessly, I haven't yet been able to establish this with the XbeePro modules.
Arduino Wiring configuration:
0 / RX (leave)
1 / TX (leave)
2 - LCD D7
3 - LCD D6
4 - LCD D5
5 - LCD D4
11 - LCD Enable Pin
12 - LCD RS Pin
14/ A0 used as NewSoftSerial RX - connects to Xbee TX
15/ A1 - used as NewSoftSerial TX - connects to Xbee RX
We will be using the LiquidCrystal library to communicate with the display.
As well as the NewSoftSerial library for the Xbee.
You can download it here: NewSoftSerial
It allows you to connect the Xbees TX/RX to other digital pins on the Arduino.
This means that the Arduino's serial pins are kept free for use by the USB when uploading.
(You can download the pde. files below)
Sketch One (InstructablesDisplay.pde)
This example will test the display without using wireless communication.
The code will print ' Instructables! ' on the top line of the display!
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
  // set up the LCD's number of rows and columns:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print(" Instructables! ");
void loop() {}
Sketch Two (mySerialDisplay.pde)
This sketch displays text on the Altoids LCD via Xbee wireless from the PC serial monitor.
The initial startup screen shows
1. 'Instructables, altoids display'
2. (delay of 5 seconds)
3. 'Waiting for serial input...'
This sketch displays text sent over soft-serial (digital pins)
using the NewSoftSerial library. (RX - 14/A0, TX - 15/A1)
Modified SerialDisplay example to include soft-serial for Xbee
A.dlp 28th July 2010 for Wireless Altoids Display Instructable
www.instructables.com
#include <NewSoftSerial.h>
// initialize the LiquidCrystal library with the numbers of the interface pins
// initialize the NewSoftSerial library RX-14/A0  TX-15/A1
NewSoftSerial mySerial(14, 15);
void setup(){
  lcd.begin(16, 2);
  // initialize the serial communications:
  mySerial.begin(9600);
  // print text 1st line
  lcd.print("Instructables");
  // set cursor to 2nd line
  lcd.setCursor(0, 1);
  // print text on 2nd line
  lcd.print("Altoids Display");
  // wait 5 seconds till next message
  delay(5000);
  // clear the screen
  lcd.clear();
  lcd.print("Waiting for");
  lcd.print("serial input ...");
void loop()
  // when characters arrive over the serial port...
  if (mySerial.available()) {
    // wait a bit for the entire message to arrive
    delay(100);
    // clear the screen
    lcd.clear();
    // read all the available characters
    while (mySerial.available() > 0) {
      // display each character to the LCD
      lcd.write(mySerial.read());
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
45
Author:Alexdlp
