3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wireless Bird Feeder Webcam
Here is MY make of the bird feeder webcam that is based on a few of the others i have seen posted lately. I thought it was a great idea, so I decided to make one myself...
see it in action here.
jay.mov592 KB
Step 1Gather Up Materials cut for your 2 "houses"
Gather Up Materials cut for your 2 \"houses\"
I am constructing two houses that are pretty similar... One for the birds to eat out of, and the other to protect the webcam from the outdoor elements.
You need:
>2 roofs - approx 7"x10"
>2 back walls approx 5"x5"
>4 side walls approx 5"x7"
>piece of plexi glass or real glass approx 5"x7"
>gorilla glue
>caulk for weatherproofing and sealing up area where webcam line runs in.
>paint of your choice. i used hunter green.
I cut the side pieces for the houses around 7" wide by 5" tall with a slight angle cut on the top so the roof is attached later, it would have a slant to divert rain to the rear. You will need 4 of these. (2 per house)
Also the "back wall" is approx. 5" wide, I cut these pieces after i cut the slant in the side pieces so i could find just the right angle to trim- so the roof would fit nice and flush later.
For the Bird food house, i am leaving the front open and adding a small wall for the birds to stand on while they eat, and to stop the seed from blowing around. I also cut the ends of "back wall" at a slight angle so when the sides are attached, they will flare out in the front , allowing a more open space for the birds. Also for the bird seed house, i applied the 7"x10" roof longways, whereas the webcam half will be installed the other way around, so there will be more of an overhang in front of where the plexiglass ends up... more overhang, less chance of sun being too bright in the lens... (phew... bare with me here, the pictures should make this a bit easier to understand!)
7 comments
Oct 31, 2011. 12:37 PMvjourdain says:
Hi ! Just a note to say the link to your site to see that live cam in action doesn't work anymore. But since the last comment is 5 years old, I shoudn't be surprised I gues ...
Sep 5, 2011. 9:19 PMcharlessenf-gm says:
I, too, had a question about the camera. The ones I first saw on that web site (wireless) all mentioned that brick walls would impair reception and the number of walls (sheet rock, etc.) between the transmitter ad receiver would similarly deteriorate reception.
Can you let us know specifically which unit you are using, the distance between transmitter and receiver, the number and type of walls between the two and the quality of reception you are experiencing.
Thanks
Nov 30, 2010. 3:17 AMrendermatt says:
Do you think this one would work?
http://www.palmvid.com./content/categories/video-cameras/sub-categories/security-cameras/products/cmos-weatherproof-camera-with-microphone.html?tab_flag=general#tab
Not wireless I know but its a great deal 14$!
May 28, 2008. 5:22 PMsrt047 says:
Is this always on or does it only record when there are birds? Some of the commercial Bird Cameras will detect birds and then turn on.
Nice setup!
Feb 5, 2008. 5:58 PMTHE_GEEK2007 says:
Which camera do we use 1,2,3,4 or iSight? TGT
Mar 29, 2007. 11:22 AMHamO says:
Excellent, well done. Do you need to get model release from the birds, or is free feed enough payment? Good instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:fleanine
