Wireless Dance Costume
Creating a wearable costume which can transmit wireless data can be a fun and useful, especially for dance performances.  A team of us created a dance shirt which measures arm position (bend sensor) and force on the wrist (pressure sensor).
You will need the following:
  • Conductive Thread
  • LilyPad
  • LiPower
  • Lithium-Ion Battery
  • 2x LilyPad XBee Breakout Board
  • 2x XBee
  • 6 pin header
  • 2x 15K Resistor
  • Flex Sensor
  • Pressure Sensor
  • Shirt
Step 1Setup XBee Modules
Setup XBee Modules
We need to designate one XBee as the Coordinator and one as the End Device (AT MODE).  Soldering a 6pin header to a LilyPad XBee Breakout allows for easy programming with the standard USB-FTDI connector which comes with the LilyPad Pro.  We used XCTU  to program the XBee units.  Make sure the high and low destination address of the End Device is 0.  This ensures that the End Device communicates with the Coordinator.  It is also suggested to name your own Node Identifier, this must be done on BOTH the Coordinator and the End Device.  For a great tutorial on programming XBee please consult Ladyada.  (Note: XCTU works under wine for linux)
2 comments
Jun 25, 2011. 1:54 PMgkern says:
Trying to find the Max code files?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:quasiben(Electric Stitches)
