Introduction: Wireless Fm Transmitter Hack
Picture of Wireless Fm Transmitter Hack
I was unable to find a FM transmitter that can play my music from my iPhone without the cracking, I needed one that was small and was able to work using power from the phone.
The SOL FM connect was relatively small and already had a great signal, so I took it apart and added a 12 inch antenna.
Step 1: Taking the SOL Fm Connect Apart
Picture of Taking the SOL Fm Connect Apart
The FM Connect I found at www.solmarketplace.com .
Firstly, I used a pry tool to free the right mn button, it is simply clipped in.
One screw holds the rest of the case together. After removing the screw, use the pry tool to open the casing.
Step 2: Adding the Antenna
Picture of Adding the Antenna
If you take a close look at the board, you will notice a strip of unmasked copper at the bottom of the board. This is the internal antenna, I used 24 AWG solid hook up wire to make my antenna.
I cut a 12 inch strip and soldered it to the board as shown.
Step 3: Putting Everything Back Together
Picture of Putting Everything Back Together
To make it easier, I used the soldering iron to make a hole in the left bottom corner of the case. Slide the antenna through and put the case back together.
PhilippeG1 (author)2016-09-25
https://www.youtube.com/watch?v=-erq5VOw4-s&index=2&list=PLoQXQojCEVHRfwHVx83rEDFNLVJ7v070k
missing04link (author)2012-10-13
what would be the range on something like this?
SexySTUD.nu.1 (author)2012-08-28
btw your ruler in that picture is measured in cm not inches :)
About This Instructable
8,991views
26favorites
License:
More by lwilliams28:Wireless Fm Transmitter Hack
Add instructable to:
