Picture of Wireless Internet Cantenna
This is about making an antenna using a usb wifi adapter, and an old fire extinguisher I never got around to refilling
I used a hacksaw, a dremel with the heavy-duty cut-off wheel and some small files
To figure out where to cut, I drew lines to cut along, on the outside of the extinguisher body. This includes a nice ink pen, an architects scale (tri-angle type ruler), and a piece of paper. The ink pen could have been a scribe, instead. A sharpened nail, or ice-pick would work for that
I went and recycled a few photos between steps, as I didn't take enough pictures during the construction
Step 1: It all started with Pachanka's Wokfi
Picture of It all started with Pachanka's Wokfi
After reading another instructable on how easy it could be to build a parabolic antenna, I wound up with this
And this, is a 24 inch wok I found at Goodwill for $7, mounted on top of a telescope tripod. Handles were removed and the thumb-fi taped and hung off of some string into the focal point
But before I could test this wokfi, I read yet another instructable for a yagi cantenna, and after following some of the links in the comments I decided to build this cantenna
Step 2: In hindsight
Picture of In hindsight
I knew I should've stopped and took pictures, but I didn't.
So this is what I started with, a Kidde fire extinguisher that was empty and had been cluttering up a shelf for several years now.
It has an aluminum body with a nice flat bottom, which I thought would work well as a waveguide.
It measured around 3-1/4 inches outside diameter. This is like the kind you might find in a car or around a kitchen. If it had a plastic body, I suppose it could be wrapped in aluminum foil, but I would've scrapped the idea and gone for some exhaust tubing or something like that.
1-40 of 72Next »
spawnos37172 years ago
Would it be possible to multiplex a couple more wifi adapters into "the can" to further acquire signals?
Shadetree Engineer (author)  spawnos37172 years ago
As far as I personally know, I very much doubt it. Doesn't mean it's impossible, but I think there'll be all kinds of technical issues that will make such a build way too complicated. Just inserting a dead unit will interfere with the first one. Multiplexing just two USB adapters in any kind of antenna configuration is too much challenge for me! Even if all you did was use the adapters as-is with no can. I think you'll need to write a custom driver to do it.
If all you want to do is just grab more signal, the best approach is to increase the physical size of your antennas 'ear'. In other words, take a look at parabolic dish antennas. The bigger the dish, the more signal you can grab out of the air. And any size dish can be made to work with the same adapter.
A less effective, yet improved alternative is to add a cone to the end of the can.
PS: Something you might want to take a look at is what I'm using these days. A Ubiquiti Bullet.
sn00ze3 years ago
this page has some good images explaining where everything goes urbanwireless.info
sn00ze sn00ze3 years ago
Shadetree Engineer (author)  sn00ze3 years ago
Nice. That site keeps all the research for can dimensions as simple as possible.
cotton6 years ago
it will work on a old satilite dish
Shadetree Engineer (author)  cotton6 years ago
Yes, it will.
no i meant as in use the oringinal antana at the end of the arm poiting at the dish and wire it into a wireles card
Oh okay. Main problem is the waveguide that came with the dish is about one inch in diameter, which is for a much higher frequency than 2.94 Ghz. I would recommend installing a coax connector into a can like my fire extinguisher approach, with a tuned length of wire soldered on the inner end to act as the active part of the antenna. Then you can connect a pig-tail from a wireless card to this antenna. Try Seattle Wireless this site seems to have some current info, they link to cantennas, which use this connection method.
enf0rcer1213 years ago
i just completed mine like this and picked up 7 more connections
bugmenot54 years ago
 Had there been any pressure inside the extinguisher there is no possible way you could have opened it by hand. For experimental purposes, try doing so with scuba diving equipment.
Shadetree Engineer (author)  bugmenot54 years ago
Uh Ok.  That must be why I emptied the extinguisher!  Though I dimly recall having thoughts of an exploding white cloud of powder shooting into my eyes as being somewhat instructive.
Your proposed experiment I'm assuming, is to attempt unscrewing a fully pressurized scuba tank?  Huh, I remember wanting to do that when I was in high school.  I don't know if it was the A-Team or McGuyver, both of those shows were playing at the time. But they were the inspiration for that scuba tank fascination.
Did you know that a steel scuba tank if cut in half, has a wall thickness of over 3/8ths inch?  It took me a while with my sawzall, but I've done that once.
ahahahahahahahahahahha.........
sarcasmmm........
11richie214 years ago
do you know if this "cantenna" works with an xbox 360 and can you use a wifi max adapter. thanks
Shadetree Engineer (author)  11richie214 years ago
I'm not too sure about the 360 adapter as I never used one. If it can be connected to the 360 by a cable, maybe 6 feet in length, then it should be no problem as you would just put the 360 adapter inside of the can instead of the adapter I used.  If you are using the official 360 adapter, that appears to use an external antenna, so I would just put the antenna inside the can with the adapter arttached to the outside. Use a usb extension.
The WiFi Max adapter appears to be an access point for your 360 to connect to. It looks like it should work exactly the same way as what I did, just accomplishing a different purpose.
Did you know that you can use a router with built-in wireless on your 360 to connect to another router? Look at DD-WRT, that's an alternative software that can run on a router. It allows turning the router into an adapter, which means you can plug an adapter into the ethernet port instead of the usb.
ok thanks! good to know
sn00ze4 years ago
(removed by author or community request)
Shadetree Engineer (author)  sn00ze4 years ago
Nice site, keeps the panic level down!
McGragger5 years ago
is this the correct way to face the thumbfi ? Which side is the internal antenna on?
Shadetree Engineer (author)  McGragger5 years ago
I'm not sure what you mean by 'facing the thumbfi', but in this photo I made the mistake of inserting the adapter too far inside of the can. I didn't find this out until later, when I adjusted the insertion depth for best signal. I have tried putting the adapter into the can with either side facing forwards, and found no significant change in signal levels. I never cracked this model of adapter, so I'm only assuming that the internal antenna is located at the tip, that it is likely formed directly on the circuit board, and that there are no other components inside of the adapter to block the 'backside' of the internal antenna. ps - check out the 'Conetenna' tutorial, where I add a cone to this can to gain more signal. I think I put in some advice on cone layouts that can be sized for any dimension of can opening. My latest connection with the 'Conetenna' is just over a mile, netting a very useable connection speed.
i would say so!
k_man935 years ago
looks like a cool hideout room thing... and its practical!
geeklord5 years ago
Gotta love those people who leave their wireless' name as the default and don't add any security :D
i love that too
xvitox5 years ago
Hey do you wanna send me a link for the wireless adapter that you used?
Shadetree Engineer (author)  xvitox5 years ago
pm
It would be nice if the transceiver was at the lower side under the can so a boot could be made of silicone to keep water (rain) off the USB connector.
The signal is polarized, it works better if you rotate the antenna for best results, not for water-proofing. If you make a boot, then it shouldn't matter which way it is.
lil jon1685 years ago
how do i get wirless inter bet when i have DSL
Shadetree Engineer (author)  lil jon1685 years ago
DSL is usually a really fast connection to the internet. Faster than most homemade wireless set-ups. I'm going to assume you have a DSL modem and don't mean to abandon the DSL connection, but would like to add wireless to it. Or does the modem have wireless already, and you just need to install wireless on another computer? In either case, buy a router with Wi-Fi built-in, or a Wi-Fi adapter. And in the case of the adapter, follow this instructable or one from the Wi-Fi Group to connect to your modem from the treehouse!
can u send me a link to a wifi adapter cause i dont relly know wat ur talkin about
Ah well, sure. Check your message box.
For some reason, i just don't think a cantenna is as good as a wokfi or parabolic reflector.
Well, in the case of my waveguide 'Cantenna' described here, you are absolutely right! If you should happen to see a newer antenna creation, called the 'Conetenna', you will note that it uses this can - simply adding a cone to the end to increase the signal. A really good parabolic will still beat the Conetenna.
I'll work on it, internet is expensive.
danfolkes5 years ago
Hey, cool instructable. I like the use of USB adapter insead of having to deal with pigtails and wire. You might consider popping off the case to the thumbdrive to see if you can position the inner antenna a little better. It might be out of wack. I am going to make one of these out of a juice can!
Shadetree Engineer (author)  danfolkes5 years ago
Well, I've heard a rumor that the adapters built-in antenna could be oriented 90 degrees wrong for a side mount into the can. It was recommended to put the adapter into the end of the can to compensate. The built-in antenna is usually going to be formed from the copper plating that is a part of the circuit-board. You would be better off converting to a pigtail if you want to perform surgery on any adapter. Not a crazy idea if you consider that there are self-powered usb extension cables to allow some really flexible installations!
deejaydee5 years ago
im going to buy a wireless adapter to connect to my friends wireless thats about a block away .. and i was thinkin of buying something cheap like the "ENCORE ENUWI-G2 IEEE 802.11b/g USB 2.0 802.11G Wireless Adapter" .. and im wondering will that work?
Shadetree Engineer (author)  deejaydee5 years ago
Yeah should be just the same, only the size of the hole you cut will be a bit different. I've run into a good point of view that brings up an issue with how the antenna inside of the adapter is oriented. That is, for some USB adapters, you will get a better signal if you install the adapter on the end of the waveguide tube, instead of on the side like I did here. Check out what happens if you put a tuned cone on the end of the waveguide, like my conetenna instructable.
1-40 of 72Next »
