3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wireless Internet Cantenna
Step 6Cutting the Thumb-Hole
I have a single-speed Dremel plugged into a vari-ac power supply. So it's actually a variable speed Dremel. Using a cutoff arbor and using the 1 inch heavy cutoff wheels, I cut along the thumb-hole lines I drew. It's not necessary to cut all the way to the corners on the shorter sides. I just went as close as I could, and the cutout was able to break loose just by pushing it around by hand. I would've used a utility knife to finish the cuts if I had to, but it wasn't needed this time
After a bit of filing to clean up the hole, I found that the thumb-fi didn't want to go all the way in. So, some more filing on each side to keep it centered to the starting dimesion. I was only off about a 1/16th
4 comments
Mar 6, 2009. 6:14 AMMcGragger says:
is this the correct way to face the thumbfi ? Which side is the internal antenna on?
Jul 22, 2009. 12:44 PMBriguy9 says:
i would say so!
Mar 31, 2009. 7:47 AMJSUTHERLAND8 says:
It would be nice if the transceiver was at the lower side under the can so a boot could be made of silicone to keep water (rain) off the USB connector.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:Shadetree Engineer
