Wireless PVC Badminton Volleyball Net
39,289
45
11
Published
Introduction: Wireless PVC Badminton Volleyball Net
My kids received a badminton set from their grandmother last summer which we have enjoyed immensely and play it often especially as an after dinner family game. The problem is that it is cumbersome to set up and take down for mowing the grass and the kids keep tripping over the guy wires when running through the yard, especially after dark. I decided to make a PVC net holder that didn't use guy wires to hold it up.
UPDATE: After 3 years of sitting out in the sun and rain the vinyl headband on my cheap net disintegrated. I tried a higher quality net but it was too heavy for my thin 3/4" poles and it was difficult to find the same cheap, lightweight, polyethylene net that originally came with the badminton set I bought years ago until I called the manufacturer and they let me buy some replacements from them. You may want to try 1" poles. I'm not sure they will fit inside 1-1/4" PVC anchors so you may need to use 1-1/2" anchors. The good thing about PVC is that it is cheap so you can experiment with various sizes.
Step 1:
Here is the net set up as it was designed.  It uses two 3-section metal poles that are starting to rust with guy wires on either end to hold them up.  I replaced the cheap strings and plastic stakes with heavier duty nylon cord and metal tent stakes but it was still a pain to set up and take back down.
Step 2:
By now ya'll know my fondness for PVC so I decided to replace the metal poles with PVC pipe so we could leave it up all the time without it rusting apart.  That isn't too much of a problem but I also wanted to eliminate the guy wires if possible.  The problem with PVC is that it is flexible so it isn't very sturdy unless you build a framework out of it using connectors.  I researched professional badminton and volleyball net systems and came across this volleyball net that uses flexed poles instead of guy wires to keep tension on the net.  I decided to adapt that concept for PVC but also to sink permanent female anchors into the ground instead of using temporary male anchors.
I bought a 10-foot long piece of 1-1/4" PVC pipe and cut off about a 2-foot section and drew a line around the pipe at the 18" mark.  I drove the pipe down into the ground with a mini sledge hammer at about a 10 degree angle away from the center of the net.  I would beat the PVC pipe down into the ground several inches then pull it out and bang it against the edge of the driveway to knock out the packed dirt and then repeat the process until the 18" line mark was at ground level.
Step 3:
After I finished coring the holes with that scrap piece of 1-1/4" PVC, I cut two new pieces of 1-1/4" PVC pipe 18 inches long and beveled the top end roughly the same angle I had driven the pipes into the ground.  I then gently tapped them into the holes until the ends were flush with the ground.
Step 4:
I then inserted a 10 foot long piece of 3/4" PVC pipe into each 1-1/4" anchor sleeve and then cut off the top so the top of the net would be regulation badminton height of 5 ft 1 in. I drilled a hole through the top of each pipe and threaded a nylon cord through it and tied off the top of the net. I then drilled another hole a couple of feet further down and secured the bottom of the net.
Step 5:
Here is the finished product.  The tension of the flexed PVC pipe holds up the net perfectly.  No more guy wires and it can easily be pulled up temporarily to mow the grass or store for the winter.  An added benefit is that you can literally push the net down all the way to the ground and then let go and it just springs back up so hopefully that will help the net last longer and if anyone accidentally gets clotheslined it won't hurt them.
Step 6:
Now I can throw all this junk away :)  Thanks for looking!
  • Planter Challenge
    Planter Challenge
  • Woodworking Contest
    Woodworking Contest
11 Comments
I recommend going about an inch at a time while hammering the Pvc pipe into the ground. Depends on your soil of course but couldn't hurt to go slow. Got my first attempt stuck in the ground because I pounded it in too far.
Thank you for posting this idea. My kids absolutely love badminton, but I can't stand all those staked wires. I made this last weekend and will post pics soon. I used 1 1/4" for the "in-ground" base, but used 1" for the poles because they were much more sturdy. One happy family (and Dad).
Thanks for your contribution.
This is a great idea that I have been searching for a very long time.
Can't wait to do it now.
(I would cover the anchor sleeves with something to prevent dirt or mulching leaves, grass filling up during storage).
Than you! Don't worry too much about the anchors filling up with dirt. Mine haven't and I mulch with my lawnmower. Now after a good rain they will fill up with water but that's OK. I did have to replace my net recently and I tried a higher quality net but it was too heavy for my thin 3/4" poles and it was difficult to find the same cheap, lightweight, polyethylene net that originally came with the badminton set I bought years ago until I called the manufacturer and they let me buy some replacements from them. You may want to try 1" poles. I'm not sure they will fit inside 1-1/4" PVC anchors so you may want to use 1-1/2" anchors. The good thing about PVC is that it is cheap so you can experiment with various sizes. I need to edit my instructable letting everyone know about that.
Thanks for your additional informations. They are surely help.
Will definitely make this. Any way I can do this on asphalt? I live in a row of condos and we all share a strip of yard in the back and there are trees and stuff which makes a huge problem for playing badminton...
potted plant planter - drive the pvc in there, can use for plants & badinton
I would think you could chip away a hole through asphalt or maybe use a hammer drill with a concrete bit and then widen the hole by chipping away at it with a hammer and chisel.
Thank you! We are still using it. I haven't even had to replace the PVC supports yet. After almost 3 years they have a slight permanent bend in them when I pull them up for winter storage or mowing the lawn but still have plenty of tension to hold up the net. I may never have to replace them but if I do it will cost $5 for two more pieces of PVC pipe and the hard work has already been done putting the female anchors into the ground 3 years ago.
The cost and simplicity is what I love about this project. Total with the net for the project had to be under $20. I was looking at sets on Amazon that were well over $100 and had to be filled with water or sand. Now I can have the net up in less than a minute and take it down even faster. Thanks a lot for sharing.
