Step 8Extra Information
-If you have access to a larger function generator you can use that in the same way we used here.
-Then you can also use the 555 timer, which can create the same kind of signal, but is a bit more complicated.
-So for all of the comments, here's some more info about about how this system functions.
With my size coils as seen in these pictures, based on how well you can tune the frequency, your looking at an efficiency range of about 70 to 85%. The led in the secondary coil, starts to fade when it is about 2 inches away from the primary. At about five inches, it is pretty well dark, but at four inches it is still a bit lit. If the coil is turned vertical, the led is dark. Please comment if you know why it is not bright when the receiving coil is vertical.
-Here's some variables that may change the outcome:
Wire gauge - 22
Amount of Wire - 40 feet
Capacitor value in primary and secondary - 0.02 uF
input voltage - around six volts; hint; i used a irf520 mosfet to amplify the power input from the function generator, which increase the secondary voltage tremendously. I'l post some pics soon.
usage of secondary coil - a voltage meter should be used first to see if there is any voltage; then you can attach an LED. I've gotten 5v from the secondary with my circuit from a 6.3 input voltage to the primary
umm, what do i need to put in my mobile phone, mp3 etc. to charge it from the coils?
I have a Q....
How can i figure out the number of coils?
I guess there is an interrelation of this...
But I couldn`t find it.
I am going to use a 24AWG wire for my lab.
But I don`t know how to calculate the inductance value of the wire
please..!! somebody helps me out....
One question: you said that you needed a 0.02uF capacitor so you put together two 0.01uF capacitors. But in the picture it seems that the capacitors are put in series, so the total capacitance is 0.005uF, not 0.02uF. Is that true? are they in parallel?
Moreover do you have an oscilloscope? it would be nice if you post the shape of the received wave.
Thank you
To the reason why it doesn't shine when the receiving coil is vertical to the other: As you already said the principal concept behind this is the magnetic coupling. So there's a so called Lorentz' Force involved, which acts only on vertical directions. In detail: The moving electrons in the outer coil are inducing a magnetic field vertical to the way they travel. This field works mostly inside the coil and stands vertical to the plane of the coil. Then the magnetic field itself begins to move the electrons in the wire of the inside coil, which results in another current. So if one of the coils stands vertical to the other the Lorentz' Force can no longer move the electrons and so there isn't an electrical flow anymore.
Visit http://en.wikipedia.org/wiki/Lorentz_force for more information on this and don't forget the three-finger-rule if you're using this concept ;)
Greez
