Wireless Remote Using 2.4 Ghz NRF24L01 : Simple Tutorial Using of NRF24L01 & Arduino
370,135
321
121
Posted in TechnologyWireless
Introduction: Wireless Remote Using 2.4 Ghz NRF24L01 : Simple Tutorial Using of NRF24L01 & Arduino
About: Hello I am Tech Creator Akshay I love electronics and get in touch for more projects
Hello Everyone this is my second instructable . After lots of surfing on GOOGLE when I wont able to find a easy and a simple tutorial for NRF24L01 transceiver then I decided to publish an instructable on this. This is a simple short and easy tutorial for NRF24L01 Radio 2.4GHz Transmitter Receiver. In this tutorial I am going to control led using a pair of NRF24L01 transceiver.
Step 1: Small Introduction About NRF 24L01 Transceiver
The nRF24L01 is a highly integrated, ultra low power (ULP) 2Mbps RF transceiver IC for the 2.4GHz ISM (Industrial, Scientific and Medical) band. With peak RX/TX currents lower than 14mA, a sub μA power down mode, advanced power management, and a 1.9 to 3.6V supply range, the nRF24L01 provides a true ULP solution enabling months to years of battery lifetime when running on coin cells or AA/AAA batteries .
Step 2: Material Require
  1. 2 PCS NRF24L01+2.4 GHz Wireless Transceiver module
  2. 2 Arduino any (I have used one arduino R3 & nano)
  3. Male to. femal jumpers
  4. LED
  5. Any Switch
  6. 10K resistor
Step 3: Connections
  • Connect the following pins to your Arduino:as shown in figure
  • Pin 9 - CE
  • Pin 10 - CS(N)
  • Pin 11 - MOSI
  • Pin 12 - MISO
  • Pin 13 - SCK
  • 3.3v - VCC
  • GND - GND
  • On the Receiver Pin 3 - LED
  • On the Transmitter Pin 7 - Button
  • same connection for receiver and transmitter and you can use any arduino board
Step 4: Coding Arduino
For coding arduino first we need some library files so follow the steps given below :
1. Download the ZIP file (library file zip folder from attachments ).
3. Unpack the ZIP file.
4. Go to arduino library folder
5. And paste both the folders named " nFR24L01" and "RF24" into it.
Now, program the Arduino receiver and transmitter
Code for Receiver
<p>#include <SPI.h><br>#include "nRF24L01.h"
#include "RF24.h"
int msg[1];
RF24 radio(9,10);
const uint64_t pipe = 0xE8E8F0F0E1LL;
int LED1 = 3;</p><p>void setup(void){
 Serial.begin(9600);
 radio.begin();
 radio.openReadingPipe(1,pipe);
 radio.startListening();
 pinMode(LED1, OUTPUT);}</p><p>void loop(void){
 if (radio.available()){
   bool done = false;
   while (!done){
     done = radio.read(msg, 1);
     Serial.println(msg[0]);
     if (msg[0] == 111){delay(10);digitalWrite(LED1, HIGH);}
     else {digitalWrite(LED1, LOW);}
     delay(10);}}
 else{Serial.println("No radio available");}}</p>
Code for Transmitter
#include "RF24.h"
int msg[1];
RF24 radio(9,10);
int SW1 = 7;</p><p>void setup(void){
 Serial.begin(9600);
 radio.begin();
 radio.openWritingPipe(pipe);}</p><p>void loop(void){
 if (digitalRead(SW1) == HIGH){
 msg[0] = 111;
 radio.write(msg, 1);}}</p>
Step 5: Testing
This is a last step after completing the circuit and coding part we can easily test it by switching "ON" and "OFF". .
When switch is "ON" on transmitter side connected to pin 7 of arduino then led glows on receivers side connected to pin 3 of arduino .Video Shows the output of this project.
THANKS HOPE THIS WILL HELP YOU
4 People Made This Project!
  • Spotless Contest
    Spotless Contest
  • Microcontroller Contest
  • Space Challenge
    Space Challenge
2 Questions
I'm having problems compiling your sketch. I'm getting:
error: void value not ignored as it ought to be
I've followed your code exactly as you have it with the exception of the CE, CS pins are 7 and 8. and are noted so in my sketch.
Any thoughts?
Although I do not have the code downloaded, I would think that if you look in the .h file where radio.read is defined, it is defined with void. That means that it does not return anything. Therefore you cannot assign the return value to the boolean variable done.
Can I use this to transmit numbers and display it on LCD module ?
121 Comments
Hi! Can I use the
NRF24L01 without an Arduino?
I want to send instructions and the
NRF24L01
Do what I want
to make a smart house. if not which one can I use. Sorry
for my English
I followed but the result didn't work. I tried below link (with the source code + library) and it works:
https://brainy-bits.com/blogs/tutorials/how-to-use-the-nrf24l01-2-4ghz-wireless-module
yes, same for me. the example from brainy-bits works. the code here only makes some compiler errors.
i'm already using pin 9 an 10 other action, can I use also pin 3 and 5, changing their divisors, to make them work faster, as default pin 9/10?
When i try to upload the code i get stray # in program error help?
or can i use esp 01 ?
Can it be used to receive signals from remote which uses 2.4GCOB-1A transmitter and after that transmit the signal to rc car/quadcopter ?
remote is SM-217-BKT (Syma quadcopter)
How to apply transfer audio from smartphone to speaker by this way? Coul you help me?
Even if I follow each step exactly, I get "No Radio Available"... I'm using an Arduino Uno as transmiter e an Arduino Mega as Receiver in order to switch on and off a led by a switch button. I've controlled again and again connections and it seems to be everything right. Which could be the problem?
I'm facing the same problem too
I got the issue solved by connecting VCC of nrf2401 to 5V
Did you found a solution? Unfortunately I'm facing the same problem
Can you use any other board like arduino mini instead of using arduino mega this might be a problem and please double check the connections
Hi thanks for the tutorial.. can i use multiple transmitters(min 50 tx and 1 rx) and single receiver with this RF ?? if not please let me know any alternative RF modules for 500 Meters.. Thanks!
I made the whole thing like mentioned above, but the receiver keeps telling me: 'No radio available'. I checked all the wires and I seriously don't know what to do anymore. Someone who can help me? Any ideas?
Hey, Nick.
Check out this page, there's an issue related to using Arduino Mega and the default pin 53.
http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
Hi there, I followed the instructions using an Arduino Pro Mini and an Arduino Uno, but the LED will not light and I only get "No Radio Available" in the serial monitor. Any ideas as to why it is not working? Thanks!
Did you solved the problem? I'm facing the same problem
I made it using the module shown and the high power one too. Both from Banggood. Both worked first time. Recommend using the power board too.
finally, able to run the code successfully now.
made few changes to the rcvr code to fix the radio.read error and also in my case the led was not turning off after I release the button, so I added line to turn it off
#include <SPI.h>
#include "RF24.h"
int msg[1];
RF24 radio(9,10);
int LED1 = 3;
void setup(void){
Serial.begin(9600);
radio.begin();
void loop(void){
bool done = false;
while (radio.available()){
radio.read(msg, 1);
delay(10);
msg[0] == 9;}}
else; {Serial.println("No radio available");
