Wireless Security Cam
Published
Introduction: Wireless Security Cam
Step 1: You Need
Container (I use a old dominoes tin but any will do) A phone with wifi compatibility (I used a blackberry 9300 model) And the charging cable (I used the factory USB that came with the phone connected to a USB to house power)
Step 2: Make the Product
Drill a hole the reason I didn't say you need a drill is because you can use a screw driver to make the hole use what you want Note it must allow the wire to go through the tin
Step 3: Software Needed
I used mobiola webcamera but you can use any I use that because it is the best that I know that works on a blackberry
Step 4: Test It Out
Put a hole for a camera and you are done test it out and you are done
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    sorry i have two accounts i am the maker of this and well here is the links you need for this
    http://mobiola.com/mobiola-web-camera
    thats all you will need the site shows you all you need to do it
