Wireless USB Page Turner
13,432
46
25
Posted in TechnologyAudio
Introduction: Wireless USB Page Turner
About: Im Steve, Live Sound & Recording Engineer with over 10 years of hand on experience. I enjoy late nights with my soldering iron, building guitar effects pedals and modifying anything with a circuit. : )
Wireless USB Page Turner Footswitch for tablet
This Instructiable is for a USB page turner for your tablet. I have seen a few other designs out there, but most of them are way too complicated for what it really is. I just needed a foot switch to change pages of sheet music when Im playing live, and didn’t want to pay $50 for it. This one is closer to $20 and wont take you that long to whip up. So lets get to it!
What youll need:
X1 Cheep usb optical mouse - free (if you have one laying around) best buy has cheep ones for $10 as well. Even cheaper on Ebay)
X 2 Spst momentaty soft touch push button switches - $2.99 (ebay is the cheapest place for them)
X1 Plastic project housing case - $5 (Radio Shack)
X1 mini toggle switch SPST - $ .75 (ebay)
X1 AAA or AA battery box (depends on mouse)
Some Braided wire
Soldering Iron
Hot Glue Gun
Drill & Bits
Step 1: Disassemble Mouse
First thing to do here is disassemble the optical mouse down
to the PCB. Make sure you check under the little rubber feet of the mouse for screws that might be hidden.
Step 2: Locate the Switches
Now that we have the mouse in its bare form, you will want
to locate the 2 main switches , the left click switch and the right click switch. They normally have SW1 and SW2 written on the PCB next to the switches.
Step 3: Desolder Switches
Carefully desolder both switches and solder in their place, the
SPST soft touch switches. It does not matter what wire goes to what prong of the switch. This being a SPST switch (single pull single throw) the current is simply passing through and waiting for you to make the connection by clicking the switch.
I like to wrap my wires as shown in the pictures. There is a lot less of a chance of things breaking and coming apart in the future if you sturdy up your project. Us musicians are so hard on our gear! : )
Step 4: Adding a Battery Box for Power
Next, we need to power this bad boy. As you can see, optical
mice have the battery boxes made into the actual enclosures, so we will need to install a battery box in its place. You will need to get a battery box that uses the same battery’s as the optical mouse your using so the unit gets the correct amount of power. See the 2 wires you have left coming from your PCB that originally went to the battery on the mouse? Connect them to your battery box. Making sure positive and negative are hooked up correctly.
***note*** I have seen quite a few mice where the black wire is positive and the red is negative. They wire them backwards just to try and trip you up so be sure and look on the actual PCB next to the holes for the wires for any indication of which one is which. If its not labeled, your safe to go by the colors.
Step 5: Test
After the switches are in, turn on your tablet or device and
test the switches, making sure they both work and make a note of which switch is page forward and which one is page back. This will come in handy when we put it all in the case.
Step 6: On/Off Switch
Next, we want to install
an on / off switch on the project enclosure so you can turn it on and off without having to take it all apart. Locate the battery housing for the mouse. ( see pics for reference) From the battery housing, you will see 2 wires. A black and a red one. Black is ground, Red is Hot. Wire the switch in the middle of the red wire as shown in the pictures. What this does is simply makes and breaks the connection of power between the PCB and the battery housing.
*Side note* I was originally going to just take off the main on/off switch that’s on the mouse and put it up on top of the project box but most of them seem to be SMD switches (really tiny and hard to desolder (but not impossible) without special more expensive equiptment). That’s why I opted for the switch in line with the battery. I want anyone to be able to make this with as little materials as possible.
Step 7: Put It All Together
Now its time to put everything together in the case. DON’T
use metal cases for this project! The wireless signal can not transmit through metal cases, it must be plastic. ( I kicked myself for 2 days trying to figure that one out on my first build). Mark out where you want your foot switches and on/off switch and drill the appropriate sized holes for each. Then mount your switches so there not flopping all over the place.
Step 8:
The final step is to mount the battery housing and PCB. Now
there are 2 ways you can do this and both are dependent on what type of mouse you are using and how neat and clean you want to get.
The proper way to secure the PCB would be with some stand off posts and screws. But If your going to do that you’ll probably want a drill press or at least a dremel because most of the holes on the PCB will need to be bored out for posts to fit.
Now most of us don’t have that time and we just gotta get it
done, so I opted to just use some hot glue to hold the PCB and battery housing to the inside of the case. (just be gentle with the pedal when in use)
Step 9: Optional Stuff
Of corse there are all kinds of things you can do to label and decorate the case. I wont get into to much of that there, all I did here was paint the case, print off stickers and clear coat them onto the case. Quick and cheep.
**TIP** You can get optical mice on Ebay for around .99 - $3.00 that are tiny. So tiny that the entire mouse, case and all will fit in your project enclosure. If you go this route, you won’t need a battery box. You can just mount the whole dang mouse in the box.
You could also add an LED to the unit by using a DPDT switch instead of a SPST, with an LED & resistor if you want to see when the unit is on. The possibilities are endless!
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    25 Comments
    Just a question.
    Are you using a wireless usb mouse with a receiver that plugs into a usb port on a tablet, pcor laptop?
    Yes, that's exactly correct. I just bought a bunch of the mouse's on eBay for $0.99 a piece and used thier guts.
    Interested in selling one? Let me know the price + shipping.
    Sure! Send me an email at audiosolutionstc@gmail.com and we can get your address and info
    I'm not too good with a soldering iron due to poor vision & a damaged hand, so I'd be interested in buying if the price is in my budget range.
    I'm using Lyric Pad and want to be able to remotely turn pages from one song to the next. I know that Lyric Pad supports bluetooth page turners, but not sure about usb.
    Most of the time it is supported, but not always. When I run into this as I do with iPads and Apple products, I simply use a Bluetooth mouse instead of a USB mouse. Same steps and principles, just a different method of communication between the pedal and your tablet. You can find the Bluetooth mice on eBay as well
    How does clicking the right/left mouse button turn the page? What software are you using? My Adobe pdf viewer doesn't do this. Is there a way to configure Adobe to do this? Does this only work on tablets or does it work on PC's also?
    Im using the Android app called Mobilesheets by Zubersoft. In the options of this program (as well as many other sheet music programs) you can tell the software to use the mouse clicks for page turns. Mobilesheets already came set up that way.
    Im not sure if you can do that in adobe pdf viewer, but its worth a shot taking a look through the options. It seems like you should be able too because I also use this page turner for when im reading e-books. which are .pdf ' s and it works fine
    thanks for the app info this has changed everything :)
    And a very neat pedal by the way.
    Please link a picture of the assembled mouse as shown from the sellers, i need this pcb size for another project!
    I just made myself something similar to this using an old foot pedal I had as well as a bluetooth mouse. It works great with MobileSheets, with one exception. Everytime I click to turn a page, there is a mouse pointer that appears on the tablet screen. I can't seem to get rid of it, or even control where it appears to move it out of the way. Have you had a similar issue? If so, how did you correct it?
    you cant get rid of the mouse icon. It's there because that is essentially what the pedal is. It shouldn't be too cumbersome though. it only appears for a few seconds when you switch the pages. Try plugging a regular mouse in and moving the cursor off the screen so that you don't see it when the pages are turned.
    Wait, does it have to be a Bluetooth mouse?
    Nope. I used a wireless usb mouse in this build. Bluetooth will work as well. you could even run an old fashion cord if you wanted to
    i don´t understand. How does an USB mouse connects in a wireless fashion to a device?
    when you buy a wireless mouse, it comes with the mouse itself (that's the transmitter) and a little USB dongle (that is the receiver) When you use the mouse, it sends the signal to the receiver that's plugged into your USB port and you see the results on your screen. I hope this answers your question. I realize that I did not post a picture of the little USB dongle that comes with the wireless mouse. Mostly due to the fact that no modification is done to it and I think everyone knows what to do with it
    oh, you wrote usb optical mouse, one can understand that as a wired mouse....
    nice instructable..
    You could make this even better with a bigger enclosure that could house a rechargeable battery, and a port with a microUSB to hold the tablet in place.
    for sure.You could probably fit all that in this case if your good at Tetris : ) its 6x4x21/4 and even with all that in there I still got a little over 4 square inches of space left. Plus you could re situate the PCB to accommodate for more items. I just kinda stuck it in there. I really like that rechargeable battery idea. I mean the batteries last forever in these as it is, but with that, it would last a lifetime! and you could charge them up when ever you wanted .
