Introduction: Wireless Communication Arduino RF
433Mhz RF Transmitter + Receiver Module Link Kit will allow us to connect two Arduinos and that can communicate. Data you send on computer Transmitter show on Arduino Receiver screen.
Final result video --- http://youtu.be/g-GxWBakV-8
Specifications:
Receiver module parameters
Product Model MX-05V
Operating voltage: DC5V
Quiescent current: 4mA
Receiving frequency: 433MHZ
Receiver sensitivity:-105DB
Size: 30 * 14 * 7mm
An extra antenna is needed, please use spiral 50Ω a quarter wavelength antenna
Technical parameters of the transmitter head
Product Model: MX-FS-03V
Launch distance :20-200 meters (different voltage, different results)
Operating voltage :3.5-12V
Dimensions: 19 * 19mm
Operating mode: AM
Transfer rate: 4KB/s
Transmitting power: 10mW
Transmitting frequency: 433M
Pinout from left to right: (DATA; VCC; GND)
Step 1:
You will need for this project:
Arduino Uno
Arduino Pro MINI (you can use Uno instead of Pro MINI if you want)
WH1602 or HD44780 16x2 Character LCD Display
433Mhz or 315Mhz RF Transmitter + Receiver Module Link
male-to-male cables
male-to-feemale cable
10k potentiometer
3.7V battery
Step 2:
Remove Atmega328 from Arduino UNO
Using male-to-female cables connect Pro MINI to UNO RX-RX; TX-TX; RST-RST; GND-GND; VCC-+5V
Change in Tools-Board-Arduino Pro or Pro MINI
Upload sketch
Step 3: Receiver Code
#include
#include
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
char cad[100];
int pos = 0;
void setup()
lcd.begin(16, 2);
lcd.setCursor(1, 0);
vw_setup(2000);
vw_rx_start();
void loop()
byte buf[VW_MAX_MESSAGE_LEN];
byte buflen = VW_MAX_MESSAGE_LEN;
int i;
if( vw_get_message(buf, &buflen) )
if(pos < 2)
lcd.setCursor(0, pos);
else
pos=0;
lcd.clear();
for (i = 1; i < buflen; i++)
lcd.print((char)buf[i]);
pos++;
Step 4: Transmitter Code
#include
char cad[100];
int i=0;
void setup()
Serial.begin(9600);
vw_setup(2000);
Serial.print("End with \".\" each data");
void loop()
if( Serial.available() > 0)
cad[i] = Serial.read();
i++;
if( cad[i-1] == '.')
cad[i] = '\0';
i=0;
vw_send((byte *)cad, strlen(cad));
delay(400);
Step 5: Receiver Scheme
Step 6: Transmitter Scheme
Step 7:
Press Enter.
THATS ALL!!!
Thats my video with final result: (too long I think and on Russian, youtube subtitles are not so good but you can on it)
If you have questions please write in comments.
