Step 3Op-amp circuit
There are two stages between the LED on the main router board and the rev counter.
1) Isolate the op-amp circuit from the router board. This is done with a 'buffer' in the form of a 74HC04. An invertor that has gates which will not draw any current from the router and will output a signal based on the inverse of its input. This guy comes with 6 gates, so if you want to get the same output signal as the input signal you tie to gates back to back.
Missing Link) I had an intermediatary stage that was designed to smooth the square wave signal driving the LED to a nice analogue rising/falling charge to the rev counter, however the mechanics of the counter provided the smooth necessary. So, in some of the diagrams you'll see and RC Low pass filter.
2)The Op-amp. I choose a very old chip, the LM 741, which worked but came with a lot of limitations that drastically affected the design. Note how the rev counter never goes to zero, and the range seems to hover around the center of the dial. Limitations of the op-amp. Leason learned and over the coming weeks I'm going to improve this circuit to have a wider range output.
Simplest solution would be to take your +12v output and split it with a ladder bridge. Energy wasteful but easy to build and pretty much rock solid.
Next is just feeding the +12v into a +5v regulator circuit (chose your flavour).
The last is just salvaging a small enough switching supply with the needed voltage outputs. (ah salvage) =D
