Step 4Parts & tools
Rev counter: This is the part I'm 're-using', a VDO meter, still have some fishing boat gunk on it. Testing showed its characteristics were that it liked to be fed a linear input of 0-12V
Router: The smallest PCB form factor in the market that I found was the Buffalo
Software: I installed the http://www.dd-wrt.com/dd-wrtv2/index.php This isnt strickly necessary but I cant prop this software enough.
Wood: Oak plank from local hardware supply (or home depot)
Bread board for testing and Protoboard for the final op-amp circuit
Op-amp: 741, will use a part better suited to this application in the next revision of the D to A circuit
Buffer: 74hc04 hex invertor
Decal: overhead projector sheet, suitable for your printer (laser/inkjet)
Tools
Electronics: Soldering iron, Multimeter and scope if you have one for fault testing
Carpentry: scroll saw, table saw, carving chisel, mortising tools, glue & dowels
Decal: any drawing application.
and most of your digits still attached
Add Comment
