Parts and tools needed:
Soldering station
Screwdriver
Something to cut the pcb
Wires
1x tip31 transistor
1x Airwick motion sensor
1x Wireless doorbell
Remove these ads by
Signing UpStep 1: Digitized sensor input
Tnx Doug Paradis, this step gave me some trouble.
I only changed a part of his method, I just used some solder and no drilling.
Visit Our Store »
Go Pro Today »
http://www.youtube.com/watch?v=hXeync9_76U
Hope you like it! Its conected over the mic input. The voltage must not exceed 0.7V! The software used on the computer is iSPy .chears:P
The positive side of the battery connects where it was always supposed to connect. The batteries negative end connects to the tip 31 ground, and the tip31 center pin connects to where originally the batteries negative was connected to the housing. And you use the battery that was intended for the bell.
Il check out the model. Hope I helped.
I will try to make something cheap and easy :)
Well anything is posible, the real question is: What do you need :).
And orks from tray. try it :
http://www.ispyconnect.com/download.aspx
