Wireless Robot Communication Through Ethernet
Published
Introduction: Wireless Robot Communication Through Ethernet
Communicate with a Raspberry Pi robot over an old router or access point. This is helpful in making longer-range robots.
Step 1: Get Supplies
You will need: A Raspberry pi with imaged sd card, ethernet cable, power supply for Raspberry pi, wireless routeror wireless access point (I am using a D-link Airplus 2.4GHz Wireless access point which I got for about $15 on ebay), and a power supply for your router/access point.
Step 2: Configuring Your Router/Access Point
First, connect you Router/Access Point to your computer via ethernet cable and power it up. Then, type the Router/Access Point's ip address into the browser bar of your web browser (you can find the ip address of your device by looking up the manual) sign in using default of set login info. Next, set your device as an access point. Turn on DHCP and set a starting ip address. Remember this address. It is now safe to unplug your device.
Step 3: Connecting to Your Raspberry Pi
Connect your Raspberry Pi to your access point via ethernet, then power up your access point and Raspberry Pi.
On your computer or tablet/phone, connect to your access point's wifi. After you are connected to the wifi, open the remote desktop application on your computer or tablet/phone. Type the DHCP server ip address you set earlier into the ip box, then click connect. You will hopefully be asked for your Raspberry Pi login information. If not, make sure you entered the right ip address into the address box.
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Great info, thanks for sharing this! Do you have a long-range robot you've made? I'd love to hear more about that!
    I have not built any long-range robots by myself accept for blinking lights/camera robots to test the range of my access point. I got this idea from my FIRST robotics team which uses a short-range ethernet radio to connect to the robot but does not use remote desktop. I mainly use this idea because I can use any wifi enabled devise to control my robot without having to download programs like putty to communicate with my robot.
