Attach a spool of wire and a hypodermic needle to a ball point pen barrel to make an aid to make point-to-point wiring easier to do. The board shown is a microprocessor system board with a 8085, 2764 and 6464 - that is, the CPU, EPROM and RAM - and some additional glue circuitry.
Step 1: The parts
A hypodermic needle. Get the disposable type with a plastic collar, as this will need to be cut down to make it fit in the nozzle of the ball point pen.
A (used) ball point pen. I acquired one with a metal nozzle as it would probably last longer.
The spool of enamelled wire was from a relay, 12 V changeover contacts - the rest of the relay was dismantled with care not to damage the spool of wire. Other sources are transformers and rf chokes.
Some two component epoxy to cement the needle to the nozzle.
A screw long enough to hold the spool of wire (not shown)
1-40 of 48Next »
tom311571 says: Jan 3, 2013. 12:50 PM
very cool thanks!
cyber_meat says: Mar 23, 2008. 2:19 PM
aren't hypodermic needles illegal?
DojoMojoMofo in reply to cyber_meatJul 11, 2012. 4:01 PM
If they are illegal where you live, you could probably get away with using an inflation needle, like you would use to pump up a soccer/volleyball/basketball with.
MaXoR in reply to cyber_meatMar 3, 2011. 12:13 PM
Not in Canada at least. We can go to any hardware, drugstore, or even the dentist for just one or two. I can also find them at pet stores sometimes, and the flooring department at most warehouse stores. You use the large 50CC ones for flooring, to apply glue to area's that are bubbled. Either way, they will have those metal tips you're looking for.
jasen in reply to cyber_meatFeb 20, 2009. 3:15 AM
That depends where (and who) you are. some places put legal controls on the possession and transfer of hypodermic needles. this has changed with the spread of HIV Blunt hollow needles are legal most places, they are used in things like inkjet refill kits. It may be possible to roll a needle for this instructible from stainless steel shim (eg the sliding cover of a 1.44MB diskette) as the needle is just used as a guide for the wire.
bgugi in reply to cyber_meatMar 23, 2008. 3:35 PM
why would they be? unless they are filled with a substance that is...
cyber_meat in reply to bgugiMar 23, 2008. 7:14 PM
the last time i checked you can't buy hypodermic needles off the shelf anywhere legal. and besides how would you get a hold on one legally
chalky in reply to cyber_meatAug 11, 2008. 3:53 PM
eerrmmm just go to the chemist(UK)and ask for a box of them.
CuriousInventor.com in reply to cyber_meatAug 9, 2008. 8:24 PM
I got a free one from a pharmacy to apply acetone to an acrylic box joint, and I think the pharmacist actually believed me when I said it was for a science project. Beforehand I got turned down by a walk-in care place--they did not believe me.
You can also buy non-super-sharp ones in bulk from mcmaster or places that sell solder-paste dispensing syringes.
AidanG in reply to cyber_meatJul 20, 2008. 11:33 AM
I'm sure all the Type I Diabetics are plenty of proof that they're NOT illegal. Just because something is not convenient or easy to find doesn't mean it's illegal.
kenn123 in reply to cyber_meatJul 20, 2008. 9:26 AM
you can find needles at farming supply stores, pet supply stores, pharmacies, vets, etc. They are not illegal in most places in the U.S., though if you are caught with some drugs and a needle it will probably be called paraphernalia
twenglish1 in reply to kenn123Jul 20, 2008. 10:09 AM
you can also get them out of a printer cartridge refill kit
Wafflicious in reply to cyber_meatApr 17, 2008. 5:03 PM
ya!
TheMadTinker in reply to cyber_meatApr 2, 2008. 9:42 PM
I would guess that any reasonably-stocked pharmacy should have these (behind the counter), not every diabetic has an insulin-pump, so manual injection is vitally important. Professional piercers also use a variety of sizes of hypodermic needle, anywhere from 20ga all the way up to 2ga (or at least I've never seen anything larger than a 2)
bgugi in reply to cyber_meatApr 2, 2008. 9:25 PM
that's because there isn't exactly an enourmous market for over-the-shelf hypodermics, but i haven't been to a pharmacy - i am sure if you looked around you could find somewhere to buy them in person. just do a little bit of google searching, you can easily find perfectly legal medical supplies without any need for you to fax them your phd or something stupid.
neelandan (author) in reply to cyber_meatMar 24, 2008. 11:38 PM
If you can't get a hollow needle, try it with a propelling pencil with a metal tip. Or you might try using the tip of a ball point pen after emptying the ink out, and use a needle to pop the ball.
HVahead says: Oct 18, 2011. 1:46 PM
if anyone could come up with a way to combine this ible with
http://www.instructables.com/id/Precision-Wire-Stripper---new-video-links/
i would be very grateful...
mondalaci says: Jul 10, 2011. 1:22 PM
I appreaciate you making this instructable but I cannot overlook the fact that readers might have the impression that EWP (enamel wiring pen) is only useful for creating rat's nest like wiring which is not the case.
I've attached the fabulous work of Markus Gritsch who is a world class talent on applying EWP. You can see the related page on his site.
Also take a look at Roadrunner Electronic Products Ltd. who seem to be the #1 EWP tool maker
Lastly, there's a good tutorial on EWP.
Gjdj3 says: Mar 2, 2008. 5:56 PM
Nice instructable, but what is the advantage of point to point wiring?
neelandan (author) in reply to Gjdj3Mar 2, 2008. 10:06 PM
The advantage is that you can use any old perforated board to wire your circuit. All other forms of wiring up circuits need to make use of some sort of a prepared or customised circuit board.
Gjdj3 in reply to neelandanMar 3, 2008. 12:00 PM
Cool. What do you do if the wires overlap? Could they cause a short circuit?
neelandan (author) in reply to Gjdj3Mar 3, 2008. 10:34 PM
No, because the wire is insulated. I am using enamelled wire from an old relay coil for the one in the picture. Since the enamel in this case is somewhat coloured like copper, it might seem that it is bare copper. Enamelled wire is available in various colours, you might like a search on the net for details.
MaXoR in reply to neelandanMar 3, 2011. 12:20 PM
What size soldering iron do you use, and do you strip the wire ahead of time, or just solder and hope for the best?
Gjdj3 in reply to neelandanMar 4, 2008. 12:01 PM
I'm definetly making this now.
Okay, thanks!
tundrawolf says: Jan 27, 2011. 8:45 PM
Very useful. Thank you!
james.mcglashan says: Mar 18, 2009. 10:10 PM
cant u just use a solder injector to a soldering iron lol u just need to pres a buttonin ur hand or a foot switch?????
bikeNomad says: Feb 22, 2009. 10:54 AM
This actually was a product back in the late '70's: the Vector Wiring Pencil (see below).
The solderable magnet wire is still available; I bought a 1/2 lb (230g) spool of Belden 8058 "Beldsol" 36 AWG (0.01 mm2) wire on eBay for $40.
The Mouser catalog says about this wire:
Dual insulated magnet wire that combines the excellent dielectric characteristics of Polyurethane and the known toughness and solvent resistance of a Nylon overcoat. Rated by IEEE tests for 270°F usage and will solder without insulation removal at 750°F.
Mouser Electronics has this wire: http://www.mouser.com/Search/Refine.aspx?Keyword=beldsol though it costs about $53 for the 34 AWG (8057) and $61 for the 36 AWG (8058) in 1/2 pound quantities.
The wire has on its label the following note:
This magnet wire may be different from what you have previously purchased. This insulation has been improved so that it will stand more heat (130°C) and it can be stripped by use of a soldering iron or gun at (750°F).
bikeNomad in reply to bikeNomadFeb 22, 2009. 11:24 AM
I've uploaded some images of my 1970's Vector Wiring Pencil.
There are three other detailed images there.
Note in this image the spool of Belden Beldsol wire that I got recently.
As I recall, it was helpful to use your finger on the side of the pen where the wire was exposed to modulate the tension. When you wrapped the wire around a component lead you wanted tension; when you were just going to another point you didn't.
sb4 says: Oct 28, 2008. 4:15 PM
how about an inflation needle for air pumps? Tube is a bit wider than syringe needle; how important is width?
sb4 in reply to sb4Oct 30, 2008. 9:39 AM
Is scraping always necessary with enameled wire? Is there a temperature of soldering iron that would solder wire without scraping?
jasen in reply to sb4Feb 20, 2009. 3:02 AM
some enameled wire can be easily stripped by the heat of soldering some cant, scraping helps heat transfer ans wetting of the copper once wet the solder flows under the enamel and floats it off. the pen can also be used with proper wirewrap wire (eg Kynar)
andrew101 says: Jan 6, 2009. 3:03 PM
wow.... just wow.....
Tensility says: Sep 7, 2008. 10:40 PM
Nice idea! I'm building one of these for myself right now, and I intend to build one for the lab at work tomorrow.
Anyway, for those of you wanting to make one of these dispensers, note that surface mount pcb assembly technology uses the type of needle tips pictured in the instructable for dispensing electronic solder paste and glues (except that the tips are already ground down for you).
These come in a variety of gauges from 14 to 30. They are available in single unit quantity (at http://store.sra-solder.com/section.php?xSec=9 and probably others) and are so cheap ($0.15 each) that you should be able to buy a full set of gauges for a couple of bucks.
On the other hand, the company I mentioned has a minimum order amount of $25; of course, they carry an excellent line of cheap soldering tools (no, I don't work for them, but I am an excited new customer), so it may be harder to stick to $25 maximum than $25 minimum. ;-)
Also, the type of wire he mentions is traditionally called "magnet-core" wire. Some of the best rework I've seen has been done using this stuff. To answer one of the concerns mentioned in other comments, it typically doesn't have the same problems peeling away from the wire that the Kynar wire-wrap coating does.
Cheers!
chalky says: Aug 11, 2008. 4:17 PM
at first glance i couldn't understand what you were doing with this until i re-read the comments and found out that the wire your using is insulated,now i see just how'brilliant'this actually is. EXCELLENT!!!!!!!!!!!!!!
SCRIPTmaster says: Jul 20, 2008. 10:45 AM
a very nice and genius way but the wiring of complex electronic circuits in this way may be unpractical though and may lead to the problem that is called in electronics the rat's nest! nevertheless its a genius idea for simple stuff! well done!
8bit says: Jun 16, 2008. 12:02 AM
Thats amazing! I will have to make one for my next electronics project!
TJ 47065 says: Apr 21, 2008. 1:55 PM
COOL!! i could have used this for making my things. This is an AMAZING idea though THANKS!!
unspecified says: Mar 23, 2008. 4:16 PM
I'm going to just add that you want the gauge of the needle to be at least 20 - probably more like 18, so those insulin needles are out. Awesome idea!
Dms12444 says: Feb 13, 2008. 2:18 PM
You could also use this for soldering :). Great idea , keep it up
1-40 of 48Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
