im gonna show you how to wire up a car amplifier and headunit in your house without the need for a battery and charger.
This instructable will allow you to wire in the following configurations:
Amp and headunit steps 1-6
Only the amp steps 1-4
Only the headunit steps 2, 5-6
make sure you have a power supply unit that matches or is as close to the max output in watts as your amp is, you dont want your amp to burn out, i know that the Amperes(?) are important too but i dont know much bout them so... .
IMPORTANT!! dont be a idiot, turn your power supply unit off and disconnect it from the mains when your working with the cables. ALSO im not responsible for any damages incurred.
ive only seen one other instructable on doing this, but they didnt cover the headunit part of the build. the person was Br14n and a link is in one of the steps.
a video :D
http://www.youtube.com/watch?v=xI3s7F36E4c
please let me know what you think
Remove these ads by
Signing UpStep 1You will need..
a PSU (power supply unit) from a PC or XBOX,
wire cutters
a car amplifier
a headunit
The only way this could be even remotely possible would be if you were able to use at least 32 molex 12v wires (16 AWG) for the battery and at least 32 Molex Ground wires to ground it, although I might be wrong on the ground part. However, even this is nearly impossible to do.
http://i36.photobucket.com/albums/e14/eSsk8er14x/powersupply.jpg
http://i36.photobucket.com/albums/e14/eSsk8er14x/headunit.jpg
http://i36.photobucket.com/albums/e14/eSsk8er14x/wiring-1.jpg
can only output 12 amps on the 12v rails...
one rail can only handle a LOT less.
