Wiring an Xbox Kinect for USB
Introduction: Wiring an Xbox Kinect for USB
There are heaps of good instructables about hacking an Xbox Kinect. From 3D scanning to motion sensing, there's a tonne of cool stuff you can do with a Kinect, but so far there are no instructables on how to wire the Kinect for USB.
I don't know what is supposed to come in the bundle, but I bought a Kinect second hand, and got only the device. No adapters, cables or anything. So this is a quick instructable on how to cut of the original plug and wire a USB on, to use with a computer.
Step 1: You Will Need:
- An Xbox Kinect.
- A 12v 2A power supply. I used an old netbook power supply
- A USB cable
- Soldering iron + solder
- Heat shrink
Step 2: Wiring
Step 1:
Cut off the ends of the Kinect, the USB cable and the 12v power supply. Cut the Kinect and power supply close to the plug, but cut the USB with plenty of cable trailing out of the male plug.
Step 2:
Solder and heat shrink the four coloured USB wires to their corresponding Kinect wires. Red -> red, green -> green and white -> white. twist up the black wires, but don't solder or heat shrink them just yet.
Make sure there is no exposed wire that will cause a short.
I have attached I wiring diagram drawn by Ttunerboy on youtube.
Step 3:
Solder the brown Kinect wire to the 12v adapter positive, and the 12v adapter negative to the Kinect/USB black. Now you can heat shrink it (or try to, with its 3-way junction).
Step 4:
Heat shrink the whole bunch to make it neat. Maybe yours already is, but my job was disgustingly messy, and I needed to cover it up.
Step 5:
Follow the other instructable on this site, to make use of your new equipment!
This will make the Kinect work on a computer, but it will be useless with an Xbox now. If you want to continue using it with an Xbox, you can splice the wires in without cutting of the Xbox plug. If you do so, you'll need to add in a switch couple of switches at the junctions between the USB's and Xbox's green and white wires. This is because when unused, the USB plug causes interference on the data (green and white) wires.
  • Paper Contest 2018
    Paper Contest 2018
  • Pocket-Sized Contest
  • Science of Cooking
    Science of Cooking
hello, i did follow up closely but my kinetic didnt come up. although i got a msg on the system which says device not recognized. any help help please
hello ,, will it work with mac ?, i will use it in matlab for image processing
Anyone know if this is the same for the second model for the Xbone?
Hi, I've connected everything as it's said but the kinect doesn't even turn on.
First I tried with a DC adapter that it's supposed to give 1A, when I measured the current it was 0.6 mA. The I tried with another source that can deliver up to 3A and I had the same current 0.7mA.
A friend of mine gave me that kinect so I don't know If I'm missing something or he kinect is damaged.
Super. Funguje to. Jeste se s tim naucit pracovat. Skvely navod. Dekuji
This looks like it will work but I think I'll buy the adapter kit for $12.00 Seems like a safe way to connect the Kinect. Now, that being said this ible is filled with great info. I can now download the SDK for my Kinect. Thanks for the link.
Thansks, it work great! i use an dapter of 12V 3A.
What good timing, I just got a kinect in the mail today to use for 3d printing and it has this silly plug. I found a 12v 4A power supply. will this work? Thanks!
That'll work perfectly! Good luck and show the results!
Need a little clarification on this point. You say that using a 12V 4A power source will work. I would have thought that would put the Kinect at risk. Inversely, I have a 12V 1.5A power source. That likely to pose any issues?
