Remove these ads by
Signing UpStep 1: Hole / Fan installation in case
What you need is a hole in the side of your case, that is going to suck in cool air and blow it onto your preferred components. I chose to make my fan blow directly onto my CPU since I bought a big ol' heat sink with fan already. Specifically I purchased the Thermalright XP-90 shown here and below.
Some tips for this step are:
1. Be EXTRA careful to try and line up the hole you are cutting EXACTLY over your CPU, I used a laser level dohicky for this.
2. Also know your materials and what it takes to cut it, not all cases are made the same, some of the new aluminum models would probably be cut fine with a dremel but I had a tough steel case which I went overboard with and cut with a plasma cutter basically just because I had access to one.
3. Depending on your fan size and case you might have to improvise with the hardware, I thought I could get some screws to mount the fan on the case at a local PC shop but I ended up just going to a hardware store and getting some long screws, rubber washers (reduce vibration noise!), and nuts.
Visit Our Store »
Go Pro Today »
Sadly My office in my new house doesn't have a window that opens to outside:(
It works very well for a ghetto cooling system, Not so well in the summer unless you have a spot that is cool.
lol u definatly belong in my group: http://www.instructables.com/group/modthis/
i'de say hang tight... but evidently the weather has taken care of that...
lol happy modding
I'm thinking that it may be easier to attach an insulation tube to the fan and the other end out the window so that everything is easy to get to and take apart.
Much like (minus the soldering part :P ): http://www.instructables.com/id/ED1NP2U80WEP287NEL/
