3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wisconsin Cooled Personal Computer
Step 2Find an ideal barrier & window
This was kind of done for me as my room in my new apartment has one window about 3' wide and the other about 5' wide so it was a no brainer to go with the smaller side window. Then you should find a barrier (ie. a piece of wood) that you can cut a hole in and that will fit inside your window frame semi-snuggly. I happened to find an old, busted computer desk that someone threw out next to my dumpster that I brought inside and left in my kitchen for a month or so, and when I went looking for a barrier for this project actually turned out damn near perfect with almost no modification. I wouldn't expect to be so lucky but just head to the hardware store if you can't find anything suitable.
As you can see this board fits pretty well with a little space on either side, THIS MIGHT BE NECESSARY OR YOU WON'T BE ABLE TO GET IT INTO THE FRAME OF THE WINDOW!
I just measured my hole and traced it (my 120mm fan is actually almost exactly the size of an audio cd) and then drilled a 1/2" hole (wide enough for jigsaw blade) on the perimeter of the larger traced hole and then used a jigsaw to cut out the rest of the hole, you could also just go buy a hole saw bit the size of your fan which might be cheaper depending on the fan size and material. You can see my super modern workshop below (it came with the apartment!) with all the latest trimmings of milk crate sawhorses and an amazing dropcloth waste removal system.
TIPS:
Make sure you cut the hole in the board thinking about where the computer will sit on the sill so there is enough room on either side for the CD drive to come out and to access the cables in the back if you need to.
It might be a good idea to sand the edges of the hole
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:teeps
