Wolverine Moving Claws
16,477
10
4
Published
Introduction: Wolverine Moving Claws
This a cardboard version of the wolverine claws wthat when you move your hand the claws come out, after watching the movie I got the idea of making them, I'm sure you can make them better but this is just to give you an idea how a the mechanism works.
http://www.youtube.com/v/LR8A6fCtV6E&hl
Step 1: Getting the Materials
Here you will see the materials you will need and how to cut the cardboard to make the claws
cardboard
scissors
a piece of string
3 rubber bands
1 craft stick
1 round head fastener
Step 2: Putting the Claws Together
first you have to put the claws together by attaching the claws to the bend piece of cardboard, as it shows in the picture
after that you will have to tape them, you can cover them with aluminum foil if you want but thats up to you.
also ad the 2 rubber bands on the 2 external claws.
Step 3: Making the Box
the interior of the box has to be a bit bigger than the width of the claws assembly so it can move freedly inside the box, also make sure that the grid where the claws go throu, is about a 1/4 of an inch so the claws wont get stuck there,
also add the fastener 3/4 of an inch from the end of the box, and in the center thats the part that will be holding the rubber bands, you can see that in the picture
Step 4: Adding the Claws to the Box
once you put the claws in the box as it shows in the picture, you can connect the rubber bands to the fastener and add the top piece of cardboard
Step 5: Tape the Box and Get Ready to Use
this is the final step you will tape the top cardboard, and the craft stick with the top cardboard to give the box more strength ,
then retract the claws inside the box, and put the cardboard with the string attach to it between the claws and the box as it shows in the picture , tape the side the doesnt have the string to the front side of the box,
then add a rubber band around the box, so it can be hold to your and and put the string around your finger, so when you close your hand the claws will come out :)
    • BBQ Showdown Challenge
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    4 Discussions
    cool claws but couldn't you make them longer for effect? Just curious.
    at least he tried unlike some i mean ive not added an instructable yet but i will make something
    Really good Instructable!
    this thing is awesome after I just saw the new movie I had to see if there was anything I could make thanks keep up the work
