Wonders Galore Bracelet
1,696
4
Posted
Introduction: Wonders Galore Bracelet
This bracelet is my 1st bracelet design I made. I hope these instructions will help you learn how to make the Wonders Galore!
Step 1: Materials
For this RainbowLoom bracelet, you will need:
1. Rainbow Loom kit
2. Rainbow Loom hook (metal is better)
3. Rainbow Loom bands
4. 1 c-clip
Today I am using the colors pink, aqua marine, and yellow. You need 3 colors for this bracelet, or if you want another color for the extension (if you need one), that will be 4 colors.
Step 2: Placing the Bands #1
Start with your loom's arrow facing up. Get your first color (yellow) and put it from the first middle peg to the right. Then get another band, and put it from the middle peg to the left. Then place bands going up 11 times on both sides. Then go from the right side peg to the middle of both lanes. Do the same with the left. Push down the bands. Your done with the beginning of placing the bands.
Step 3: Placing the Bands #2
Now we are going to start the middle of the bracelet. Get your 2nd color (aqua marine) and place it from the first middle upward. Then go from the right to the middle, do the same with the left. Get your 3rd color (pink) and make a diamond with it. Make the diamond like this: middle to the right, middle to the left, right to the middle, left to the middle. Do this set over and over again 5 times, basically until the end of the border.
Do the border once again, over the middle of the bracelet. Place a capping band at the top of your border. After that, your done placing the bands.
Step 4: The Hooking Process
Now we are going to start the hooking process.
Turn your loom around so that the arrow is facing toward you. Go inside the capping band with your hook, and get the top band. Hook it to the right. Then go back inside the capping band and get the next top band, and hook it to the left. Hook all the top bands of the border.
Now it's time to hook the middle of the bracelet. This is for the diamond: go inside the capping band, and hook the top band to the right. Go inside the capping band again, and hook the next top band to the left. Then hook the left to the middle, then the same with the right. You can do it the other way around too, right before left, it doesn't do a change. This is for the arrow (or whatever you think it is): hook the top band to the right. Then hook the next top band to the left. Hook the last band forward. Do the same with all the other sets.
After you hook the middle of the bracelet, hook the last border, the one on the bottom. Tie it off, take it of the loom, then add extensions if you need them.
Step 5: Extensions
Add your extensions if you need them, then your done with your Wonders Galore!
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    2 Comments
