3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wood Burned Settlers of Catan Board
I recently decided to make my own Settlers board with the following goals:
- More durable than cardstock
- Prettier than anything I could buy
- Easy to use in low-light venues
- Total cost under $60
I ended up making board from basswood, burning in the artwork and finishing it with acrylic paint and shellac. It took somewhere between 20 and 30 hrs of labor to complete and is incredibly durable, functional and snazzy. If you just make the tiles and purchase game pieces, you should be able to finish in 10-15 hrs.
There are many ways to improve on this design if you have a higher budget and more time. If I were to do it again, I might opt to stain the tiles or use different hardwoods before shallcking or varnishing to provide some more contrast. The colors I chose for the game pieces aren't the best in low light.; shellecked white and yellow, and blue and green are hard to distinguish in low, yellow light. More comments later, but first here's what I used:
Supply list:
- 3 3 1/2" X 1/4" X ~4' basswood pieces (hexes, ports, longest road and largest army tokens)
- 3 5/8" X 3/8" X 3" square dowels (roads)
- 84 1" wooden coins (pips, settlements, cities)
- Shellack (Amber; 2lb cut if you're mixing from flakes)
- Wood burning pencil
- Pencil
- Paintbrush (one for detail, one for large areas)
- Ruler
- Table, Mitre or band saw
- 30/60/90 triangle guide or protractor
- Art work
- Sandpaper
For a complete game:
-2 sets of Settlers of Catan Replacement cards (need 2 sets to play with 5 or 6 people)
-2 6-sided Dice
Step 1Cutting the hexes and ports
The most important step is the first: cutting out the hexes. Having a nice monodisperse set of hexes is key to having a usable board; minor variations can cause the hexes to leave annoying gaps in the board. I'll go through the steps I used to cut the hexes on a a table.
I wanted 30 hexes for the 5-6 player version of Settlers; you only need 19.
I cut the hexes in two steps. First, I cut the 3.5" board into 3.5"X (3.5*sqrt(3)/2)" ~ 3.5"X3.0" rectangles. The rounding error is small enough that it didn't matter after sanding. See pic 1.
Each rectangle needs for more cuts to become a perfect hex; these cuts are illustrated in the next four images.
First cut:
Set your guide at 60 degrees and line up the block of wood so that the cut enters 3/4ths of the way across the top of the rectangle and exits halfway through the side. Mark the edge of the block on your guide so that you only have to measure this once
Second cut:
Rotate the block by 180 degrees and line up the cut so it once again enters 3/4ths of the way across the top of the rectangle and exits halfway through the side. Mark the edge of the block on your guide so that you only have to measure this once.
Third cut:
Flip the block over and use the first mark on your guide to make this cut.
Fourth cut:
Rotate by 180 degrees and make the final cut.
I also cut the ports and tokens at this step. I cut 14 1.5X1 rectangles, for 12 ports, the longest road and largest army tokens.
Sand all the edges and faces of your hexes. I used a hand held sander with 300 grit for this step.
14 comments
Feb 4, 2012. 2:29 PMreedz says:
This is gorgeous...
   I've always wanted to make 3d printed/laser cut acrylic version that was able to handle a high amount of stress. This however, gives a much more rustic and handmade appeal.
   Will you be doing anything to surround the borders? In the stock game it comes with the ocean pieces to tie everything together, so it doesn't separate as you play.
   Also, have you considered sending pictures to Mayfair? I'm sure they would appreciate this sort of handiwork.
Game on.
Feb 5, 2012. 5:40 AMKneXtreme says:
Very nice! Did you enter it in the shopbot or toy contest???
Feb 5, 2012. 2:42 PMPenolopy Bulnick says:
You can enter it into, I believe, up to three contests!
Feb 6, 2012. 12:26 PMmefca says:
MAN! you beat me to it! ha, i was just working out the details in my head for a woodburned settlers board and then I saw yours. Excellent craftsman ship sir. I especially like how deep the burns go in the wood. It makes it very vibrant.
Mar 2, 2012. 10:12 AMKneXtreme says:
Congrats on winning first prize :) Cheers!
Feb 27, 2012. 7:01 PMdepotdevoid says:
Very nice! At first glance, I thought, "Oh, another laser cut project I'll never be able to duplicate." On closer examination, I realized you'd done it all by hand! I'm very impressed!
I've been thinking about replacing my cardboard settler's hexes with something hand made, if I do this may just be the thing!
Feb 16, 2012. 7:02 AMObst Pause says:
Cool version you made there!
What did you do about the resource cards?
I started my own settlers copy years ago, too, but sadly never finished it. But thanks to your efforts I am considering a restart. Due to the lack of money i used thick cardboard(~40 mm), cut that and used a lot of thinned alkyd varnish to make it waterproof.
Thanks again for sharing yours!
Obst
Feb 6, 2012. 3:58 PMStephica says:
Beautiful, I love it!
Feb 6, 2012. 4:42 AMzrelaxts says:
Feb 5, 2012. 11:20 PMskiedra says:
Now that took some time and patience. :) . Well done!
Feb 4, 2012. 8:26 PMphalanx447 says:
This is beautiful. It has such a great feel to it. Nice work!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:benjib0t(Glotzer Group)
I'm a physics grad student at the University of Michigan. I study self assembly in soft matter systems. When I'm not doing physics, I can be found volunteering at Common Cycle, a local bicycle non-pro...
more »
