Wood Cheese Slicer
3,982
48
20
Posted in WorkshopWoodworking
Introduction: Wood Cheese Slicer
About: We love to create and we love trying new things. As we learn and grow we want to share our experiences with you and hopefully inspire you in some small way.
This was one of those back burner projects that we had always had on our list, but just never really got around to making it. One of those, "let's just see if we can make it" type projects. The idea was to make a wood cheese knife and I think we achieved what we were aiming for.
Check out the video we made to go with this project.
What you might need (materials):
  • Two types of wood
  • Dowel
  • Wood Glue
  • Some kind of finish
  • Food safe finish
  • Masking tape
Tools:
  • Various Sanders
  • Band saw or scroll saw
  • mallet
  • drill
Step 1: Creating the Pattern
We just created our pattern on the fly. We roughed out a shape on one sheet of paper and then transferred it to another piece. The second time we ran the pattern from corner to corner on the paper to make it longer. Then we transferred that to our first piece of wood.
Note: these pieces of wood were already about 1/4" - 3/8" thick.
Step 2: Rough Cuts
We cut the inner sections out with the scroll saw. These areas are both decorative and will help whatever is being cut to release from the blade more easily.
All of the outer cuts were done on the band saw. We made sure we stayed on the outside of the line when doing this. We will sand up to that line in the next step.
Step 3: Sanding and Shaping
We used the disc and belt sanders to shape the knife up to the lines we had created. We also spent some time thinning the stock of the blade and also adding a slight edge to it.
Step 4: Scales
After we had the shape we were happy with, we cut out the knife's scales. This is the outer shell of the handle. We just simply traced the handle of the first piece onto a second piece of wood and then made a pair of scales. We cut these out on the band saw.
Step 5: Attaching the Scales
We lined everything up and drilled some holes for the pins that will help give the handle its bulk and rigidity. We used wood glue to hold it all together and tapped pieces down onto the dowels with a rubber mallet. This worked out pretty well. You could also use clamps in this step.
Step 6: Final Shaping and Clean Up
We sanded down the remainder of the handle so that everything was flush. We then rounded over all the edges of the handle using a rotary too drum sander.
Step 7: Finishing
We taped off the blade with masking tape and sprayed the handle with a few coats of spray lacquer. Once that was dry we applied a few coats of cutting board finish to the blade. This is a food safe finish and worked wonderfully.
Step 8: All Done!
It's not the sharpest knife in the world, but it works pretty well for cutting cheese and I would assume other like foods. In the end, we set out to make something specific we had in our minds and ended up with something we were pleased with.
Hopefully, you had some fun seeing how this was made. Even more so, we hope it inspired you to make something. If you have any questions or would like to weigh in on what might have worked better, feel free to do so in the comments. If you didn't get a chance, make sure you check out the video. We would greatly appreciate it.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    20 Comments
    is tulip poplar ok for the cheese knife?
    Looking forward to getting started on this. Christmas 2018
    Cool project, looks really nice, however, how did you sharpen the wood blade.
    Thanks. Just angled it on the belt sander.
    Cool, I wonder how sharp you could get a wood knife on a whetstone.
    You can use sandpaper to get them sharp enough to be dangerous. But you should start with a hard closed porous wood like hard maple or beech or walnut. Or even better would be a rosewood, Jatoba or Bubinga would make a longer lasting edge. They are great for letter openers.
    I made a batch a few years ago, I started with some maple offcuts that were about 1/4 x 1 x 24". I glued some short pieces at the center of the maple and then cut them in half to get two knives which I shaped on the belt sander. I think I made a dozen of them in an hour or two.
    Here is one I sold on Etsy
    You would need to use a very hard type of wood to get a sharp edge on the blade. In Western Australia we have some of the hardest woods, Slow growing desert trees like Jam, Western Mayal, Gimlet to name a few.
    Ebony is 1 that ive tried thats hard and will do.
    only if you ingest it. so dont eat the knife.
    That is ASTOUNDING! I have NEVER seen a knife, constructed of any material whatsoever, that could UN-SLICE cheese like that!! (kidding of course!!). Cool project!
    It's a magical knife. lol Thanks for checking it out.
    but how does it do on a hard cheese like an Aged Gouda... its hard to cut that stuff with a steel blade.
    No idea. Can't say I have ever had it. I would imagine not well. Probably works best for softer cheeses. Perhaps bread if you could make it serrated.
    I have made knives, forks and spoons out of bamboo - and they do have their limitations. But if your willing to assume that a reasonably HARD plastic knife is good for cleaving the cheese twain, you can actually "densify" the wood, by applying a HARD resin not only into the surface layer, but through the wood it's self... There are limitations in regards to thickness and timber types and oil content etc.. but you can remove the waxes and oils with solvents and pressure treat the wood with a good hard plastic resin. The wood fibre acts as the glass in fibre glass and the resin acts as "the resin".... If you cannot pressure treat you can soak it in with solvent based thinning, and build up the layers.
    I had thought about coating it in food-safe resin. I like what you are thinking here. May have to try it if I make another. Thanks.
