Step 2Cutting the Banksia Pod
With the stem end up, you now have a flat surface for the foot of the egg.
(If you are only making an egg to sit on a shelf, you can skip this step.) I also need the flat surface to drill a hole, since I am making the egg to use as a cane handle it needs to have a dowel or fastener. Using first a 1" Forstner bit I drilled 1/4" deep, then using a 3/8" Forstner bit I drilled the length of the coupling screw. This hole is made for a brass coupling so I can screw it on to the shaft securely and it will be hidden inside the egg (handle) and shaft. Note: If you do not need the top to be removable, you can use a dowel to fasten the handle to shaft instead of the brass coupling.
Add Comment
