iImage Information
Turn scrap pieces of wood into jewelry. In this instructable I made pendant necklaces by sanding small pieces of wood and stained them with a non toxic stain. Use different types of wood (cherry, maple, ash etc) for different colours and picking wood pieces with an interesting grain pattern makes for unique jewelry.
Step 1Material:
iImage Information
- Wood
- Pendant bails
- Mineral Oil (baby oil)
- Strong coffee
Tools:
- Wood cutting tools (saw, Dremel etc.)
- Sandpaper (varying grits)
- Pliers
- Paint brush
- Rag
__________________________________________________________________
this is a neat idea!! the black stain from walnuts....
Blue stain/paint from duck droppings(their poop)
Various other colors from different flowers, reeds, grass, etc...
I have never tried the walnuts, but I have made paint from roses, & from the ducks...
I figure if the dye's safe enough to put in clothes...
Pendant bails are pretty cheap en-masse on ebay, but they come in various sizes. What size is the bail in the pictured pendant you made?
Great idea by the way!
Wow, that shows how lazy I am :/
Oh, and that's just a scrap piece of birch I had lying around. I also rubbed some mineral oil on it, and a very minimal amount of color came back off. I think you'd probably want to seal this with something other than oil or it might bleed onto your skin/clothes, or perhaps it just needs to be worked in more (I didn't spend a lot of time on that!)
Just a quick update, I applied a clear coat varnish to it this afternoon, and it didn't bleed or run at all. So perhaps just letting it soak in and dry over night then oiling it will do the trick. Will just have to experiment!
One thing of note that I noticed when using the food coloring, it didn't alter the surface at all, so you wouldn't have the extra step of having to sand again after staining it.
Now I have to go pawing through all my bits and pieces of scrap wood, Christmas presents, here I come! :D
Actually most modern finishes like acrylics and polyurethanes along with the classics like lacquer are non-toxic once they dry and can be used safely.
Another nice thing about wood pendants is the wood can be carved. I used a Dremel tool to carve in names, then filled the name with paint and sanded off the excess paint leaving only the color inside the carving.
if so, it might avoid splintering and raising the grain etc. It might also last longer.
just a thought.
Then i tried adding veg. fat or lard to make a wood wax and that didn't separate but the wood didn't take on much colour froim it unfortunately.
I think with a bit of tweaking it could work though.
