3 Simple Ways to
Share What You Make
Other ways to share:
25,313
views
Comments: 71
Rating: 4.87
All Steps Viewing
__________________________________________________________________
this is a neat idea!! the black stain from walnuts....
Blue stain/paint from duck droppings(their poop)
Various other colors from different flowers, reeds, grass, etc...
I have never tried the walnuts, but I have made paint from roses, & from the ducks...
I figure if the dye's safe enough to put in clothes...
Oh, and that's just a scrap piece of birch I had lying around. I also rubbed some mineral oil on it, and a very minimal amount of color came back off. I think you'd probably want to seal this with something other than oil or it might bleed onto your skin/clothes, or perhaps it just needs to be worked in more (I didn't spend a lot of time on that!)
Just a quick update, I applied a clear coat varnish to it this afternoon, and it didn't bleed or run at all. So perhaps just letting it soak in and dry over night then oiling it will do the trick. Will just have to experiment!
One thing of note that I noticed when using the food coloring, it didn't alter the surface at all, so you wouldn't have the extra step of having to sand again after staining it.
Now I have to go pawing through all my bits and pieces of scrap wood, Christmas presents, here I come! :D
if so, it might avoid splintering and raising the grain etc. It might also last longer.
just a thought.
Then i tried adding veg. fat or lard to make a wood wax and that didn't separate but the wood didn't take on much colour froim it unfortunately.
I think with a bit of tweaking it could work though.
(speaking of too odd to try, I'm off to see if coffee will dissolve in rubbing alcohol) ^_^
I tested the alcohol bath three times. Once with a simple dip in, then letting dry, soaking for five minutes, and soaking for ten minutes. Even after heating up the alcohol and letting it soak for ten minutes, it still did not have a usable finish. There was very little color difference from when it started.
What I ended up doing was making a tea bath for my peices by brewing a single cup of tea with three tea bags in it instead of the normal one. This concentrated the broth (and unfortunately made it undrinkable) :(
I submerged each piece in the broth using a pair of spoons and let each piece sit for ten minutes, and that seemed to do the trick. There is a very noticeable difference in the ending color as opposed to the starting color of the pendants. It is not as pronounced as it would have been if I'd used Danish oil, like I'd originally planned to, but it still a marked difference and I think the finish is usable.
If you've got any questions about what I did or the color comparison, just let me know! :)
...yeah, I give up. I also used maple, which is a very dense wood. I'm not sure what the effects of either bath would be on a more porous, softer wood like pine.
