Step 1: Supplies
A sheet of Birch plywood in whatever thickness you want. (not too thin, or it will crack and splinter when you are cutting it
Utility scissors
Exacto knife
Power drill with drillbit matching the width of the screws holding the pickguard in place
Wood stain (optional)
Wood finish (I used Deft)
Patience
lukev2 says: Jun 8, 2012. 9:49 AM
love ur bass!!!!
thepelton says: Jun 29, 2010. 4:10 PM
I found that eighth inch (3mm) plywood can be formed quite readily with an Epilog laser, if you have one. You would just have to measure exactly where each important cut went, and burn it out. If you did that, I would suggest that you just make marks where drill holes go, and then drill them to the proper diameter with a drill. I am not quite sure how to get a hole of a specific size in a specific location.
klausmanfre says: Oct 14, 2009. 2:59 PM
Nice fretless man!
LuminousObject says: Jul 30, 2009. 3:25 PM
This looks really awesome.
jp_pianoguy says: Jul 3, 2009. 10:47 AM
Love the pic of this step.
lemonie says: Jun 16, 2009. 2:26 PM
Can you show this on the guitar?
L
sexpistolsrule666 (author) in reply to lemonieJun 29, 2009. 9:24 PM
Yeah, im putting up a picture right now.
lemonie in reply to sexpistolsrule666Jun 29, 2009. 11:19 PM
I see! L
DELETED_GuardianFox says: Jun 15, 2009. 6:10 PM
(removed by author or community request)
sexpistolsrule666 (author) in reply to DELETED_GuardianFoxJun 15, 2009. 8:52 PM
The wood is so thin, a saw would splinter it. heavy duty scissors work really well.
DELETED_GuardianFox in reply to sexpistolsrule666Jun 15, 2009. 9:19 PM
jeff-o in reply to DELETED_GuardianFoxJun 16, 2009. 6:35 AM
Yup, all it takes is the right saw and the right blade. You could also sandwich the wood between two thicker sheets to prevent it from splintering.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
