Wood Propeller Fabrication
190,545
305
100
Published
Introduction: Wood Propeller Fabrication
About: I am an Aerospace Engineer. I love Technology, and Design.
This tutorial will show the steps needed for anyone to carve a propeller out of wood.
Step 1: Obtain Propeller Cross Sections
First you must have full size cross sections (about 10, from root to tip) of your propeller. There are tools online for designing propellers, but you will need some CAD software to create the drawings and 2-D cross sections. I used CATIA, but any 3-D modeling software will do. (I also have a detailed instructions on design of propellers here (www.aerodyndesign.com) Of course you will have to print out the cross sections of the propeller on to paper, at full scale size. Because you will need to cut them out and glue them to thin peice of aluminum or tin.
Step 2: Choose Your Wood and Prep It
You will need to choose your wood. This propeller is made of Hard Maple. If you are creating a propeller for acual load bearing use, you will need a hard wood like Maple. You then cut your wood into thin boards and glue them together like in the picture. You must glue them together with no gaps. You will need lots of clamps.
Step 3: Cut Out Paper Templates and Glue to Thin Sheets of Metal
You will now glue your templates onto thin sheets of metal, and then you tin snips to cut out the cross section.
You will need to file down the rough edges because the template needs to be dead on.
Typically you will want about 10 stations, or 10 cross sections from blade root to tip
Step 4: Cut the Propeller Profile
By marking the profile of the propeller (looking down on the wood) you can use a hand saw to cut out the profile of the propeller, this will save you time when you go to 'hog out material'
Step 5: Begin Hogging Out Material
Now this is the most time consuming part, you will use a chisle or draw knife, or any cutting tool to start widdling away wood material until you can start fitting on you templates to see where material needs to be taken out.
Step 6: The Fun Part Is When You Get Down to the Templates
Once you have hogged out most of the unwanted wood, you can now use the templets and hold them up to the correct stations along the blade to see where material needs to be removed. Be careful not to remove too much, you can't put it back once its gone. The hardest part will be the root area, were the templates are hard to align. Marking the front and back of the propeller with a small notch will help align the templates.
Step 7: Final Step Is to Sand and Add Stain
You can use sand paper to sand down and smooth out the contour. Be sure to start will rought paper 40 grit to 100 grit, and work you want down to a nice 600 grit or finer. Then you will apply some water proof finish. If it is an outdoor propeller you will need to use a thick water proof varnish. This propeller is for an airboat (http://www.aerodyndesign.com/FAN_BOAT/FAN_BOAT.htm)
Step 8: Propeller Duplicator
If your really ambitious, you can make a propeller duplicator, which can more or less duplicate anything, but right now its duplicting a propeller, so we call it a propeller duplicator.
I might make an instructables on how we made it, but for now some pics and a video here: http://www.aerodyndesign.com/PROP_DUP/PROP_DUP.htm
video:
http://video.google.com/videoplay?docid=-2413717528443348681&hl=en
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
  • Make it Move Contest
100 Comments
what type of varnish and/or clear coat did you use to finish it?
I'm just about done with a test prop for my ultralight and want to make sure I use the right finish.
Beautiful work!
How do I make a 3d model? Like, so that it has the right pitch and width and whatnot
Hey man, just wanted to say... fantastic job, and I would LOVE to make
one for an airplane I'm going to build, not an RC one like everyone
thinks, but an actual plane that I myself can climb into and pilot,
would this propeller do the job? I noticed it was designed for an
air-boat and my train of thought says that if it's powerful enough to
push a boat with 2 people over swamp and grass, it should be able to
taxi and pull a plane into flight, right? Well anyway, I have scoward
the internet everywhere and it's surprisingly hard to find an actual
real propeller for a real plane that I can potentially use for said real
plane, and the ones I do find cost more than my car, and designing one
takes a s*** load of math, I'm not even going to include the fact that I
never actually carved anything out of wood except for sharp points on
thin sticks with my pocket knife, so yeah, this looks like the most noob
friendly propeller design, I couldn't make sense of that propeller
designing app, but this is obviously not stuff you can learn in 10
minutes. So would just like to know if it could work as a plane
propeller. The plane will be a small single passenger aluminum plane linked below, it says balsa wood, but I'm gonna make it out of aluminum.
RC Glider Plane Balsa Frame 3D CAD Model Download | 3D CAD Browser
Cburgess,
Thanks for the questions. Also, thanks for good laugh. I would not recommend using this for a flight vehicle. It is not qualified to the correct loads, and could come apart in flight. This will be a problem if you don't have a safe place to land. I would recommend just guying one from an ultralight website. Or getting the plans for a real flight propeller at an ultralight website. Some examples:
They are actually pretty cheap:
http://www.powerfin.com/Pricing.html
http://www.arrowprop.com/up.htm
http://www.competitionaircraft.com/
http://www.ivoprop.com/inflightultralightmodel.htm
Best of luck,
Mike
Hi
what did you use of type of glue or epoxitic thank you
firstly i want to thanking you for keeping this website,
it is possible to make propeller with bamboo composite fiber material instant of wood?
yes or no
yes means why
no means why
thanking you.
Maybe, bamboo is super hard. Might take forever to carve, but might be possible
VERY NICE!! how about how many hours from start to finish do you think it took to make the prop?/
1 day to glue wood
2 nights to dry
1 day to carve it (12 hrs)
Voila.
This is extremely impressive. Congratulations on completing a project like this. It's clear you're a master of your craft :)
can you lead me to any of the sites that have the propeller design tools you speak of in this article?
Thanks. Jim Birke
http://www.aerodyndesign.com/ANALYSIS/ANALYSIS.htm
http://www.mh-aerotools.de/airfoils/jp_applet.htm
Hi AeroEngineer Do know our design of the propeller are valid for a windmill, or do you have a design for a 3-blade propeller
A windmill blade should work best if done the "opposite" way to a driven one. This means that the tip of the blade should be parallel to the direction of the wind and the base should be at about 90 degrees to that. The curvature along the airfoil should also be reversed so that the wind hits the flatter or more concave side of the blade.
Hi everyone, I'm new here and in props building (never done one before).
I'd like to build that one built by AeroEngineer, but I need help.
Firstly, he say that printing 200% pdf can give a full scale (1:1) design: well, the pdf posted on this forum (http://www.aerodyndesign.com/PROP_10/PROP_10.pdf) it's an A4 format and if I print it, even doubled in dimensions, I obtain a scaled print also (an A4 has the longer side 11" long and if doubled it reaches 22", but propeller diameter is 48"!) So, how to?
Then another question: the propeller, even if mounted in the rear of the fan powered boat as shown, is a pulling one, ain't it? Blades profile seems to confirm this supposition.
Thanks in advance for the kind help you all may give to me.
Valvolino
Why did you choose this particular foil, and is there a reason you chose to make it completely of wood rather than say, foam-filled laminate?
Fuddle,
Thanks for you questions. I used a NACA 4412 because it has a flat bottom, making it esier to carve. I used wood because I wanted to carve a propeller. I think wood propellers look great. I have started thinking about using foam and fiberglass, but foam does not make a very accurate tool to lay composite onto for high twist propellers, but wood does, so I want to use wood as my master for molding the fiberglass.
Mike
