3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wood Propeller Fabrication
  • last photo ←
This tutorial will show the steps needed for anyone to carve a propeller out of wood.
Step 1Obtain Propeller Cross Sections
First you must have full size cross sections (about 10, from root to tip) of your propeller. There are tools online for designing propellers, but you will need some CAD software to create the drawings and 2-D cross sections. I used CATIA, but any 3-D modeling software will do. (I also have a detailed instructions on design of propellers here (www.aerodyndesign.com) Of course you will have to print out the cross sections of the propeller on to paper, at full scale size. Because you will need to cut them out and glue them to thin peice of aluminum or tin.
84 comments
1-40 of 84next »
Mar 6, 2012. 10:09 AMfuddle says:
Why did you choose this particular foil, and is there a reason you chose to make it completely of wood rather than say, foam-filled laminate?
May 2, 2012. 2:29 AMfuddle says:
Superb. Thanks for the answer.
I agree there's definitely something about wood propellors that make them stick out. And 100% agreed- wood is an excellent base for a template.
PS- "props" *insert groan* on your drafting skills- or should I say "pitch-ers".
Oh dear. How pun-ishing.
Nov 29, 2008. 9:01 PMReefpimp says:
Congratulations, you've succeeded in giving everybody who reads this just enough knowlege to be dangerous. If you're considering building a wood propellor for ANYTHING that spins real fast, PLEASE PLEASE PLEASE make sure your woodworking skills are up to snuff. And use a waterproof glue such as Titebond III, resorcinol, or epoxy. Explosive delamination is a very real possibility.
Mar 6, 2012. 10:20 AMfuddle says:
What ever happened to Individual Freedom, Liberty and the responsibility that goes along with it?
The man gave an excellent instructable that was accessible to those without the luxury of a tertiary education.
Normal Wood glue is fine- see how hi-tech bi-plane fighters props were- they were used hide and hoof glue they did the job fine.
As long as the constructor follows the glue instructions (dry and free from grease/dust etc & is clamped (expulsion of air) no probs.
As far as I recall, airboat props are encased in a wire cage. If it were to delaminate- the centripetal force and airfoil vortex would blow it backwards- so nothing to worry about in front.
How Its Made (Airplane propellors)
http://www.youtube.com/watch?v=JvLra7G31cU
Stop being a girl. Something has to kill you in this life.
Jan 13, 2012. 12:58 PMitri45 says:
If i download the pdf what percentage size should i print these out at for it to be full scale
Dec 21, 2011. 11:08 PMbertus52x11 says:
That's an impressive piece of art!
You have an equally impressive spreadsheet on your personal website, though. Is it all right to contact you directly with some questions about the maths behind it?
Oct 18, 2011. 7:08 PMdavid.beck says:
gotta give you props on this one
Oct 5, 2011. 7:12 PMbroper says:
dose that achualy work
Aug 20, 2011. 1:22 PMTimmyMiller says:
I wnt to your website and saw your prop duplication machine and do you think you can put an instructable for it? I want to make one.
Jul 15, 2011. 2:12 PMliman says:
What to do if i need 60" wooden prop., can I extend values proportionally.
And which props have better characteristics and performances 2 or 3 blade propellers.
Thanks.
Feb 21, 2011. 8:33 AMishak Mohamed says:
Dear Sir,
I am very happy about your knowlege, and sapoting to next generagion,
i got this web side, 21/02/2011, I all so made propeller later i send poto
well done, excelant.
Thanking you,
Ishak M.
Feb 17, 2011. 8:45 PMjustjonty says:
Great project... thanks for posting... might have to make that pagojet (backback motor), after all :)
Oct 19, 2009. 5:28 AMleviterande says:
Hi, thank you for the tutorial but I must say I seriously dont understand how you really carv the prop based on the  profliel shapes..
you have the 10 pieces of  the metal profiles.. and then what? how do you put them on the prop, how do you cut the prop accordingly to the profile.. I am having  really a hard time understanding it..
thanx
Sep 18, 2010. 11:10 AMbobsmith760 says:
From what I see, you cut the metal template in half and carve out the inside shape. When you are done you should be able to slide the template over the top or bottom and were it touches is where you need to remove material.
Leave a reply if you have any more questions
Jun 9, 2011. 1:01 AMKelticpaddler says:
If I understand right, using the cross section profile shown above, you stick the paper to the metal and cut out the templates, keeping the WHITE parts, not the GREY parts.
In effect you have made "outside" gauges, not "inside" (or teardrop) gauges.
THen simply place them onto the prop at the correct station. Remove the material where the gauge touches (or the highspots).
Beautifully done by the way....I like it!!
Apr 10, 2010. 6:15 PMRe-design says:
Most excellent work.
Jun 21, 2009. 7:31 AMmwhitelog says:
I have a 44-inch antique wooden propeller that I would like to mount to the wall in my apartment. What is the best way to mount the propeller. I enjoy all the comments. Thank you. 54pickup
Apr 20, 2009. 4:33 PMfinnrambo says:
Sounds hard to make.
Feb 22, 2009. 4:47 PMemdarcher says:
what is that propeller for? an airplane?
Feb 23, 2009. 3:29 AMivanlp says:
Thank you really for useful practical security councils! I will try to take it for my parachute. Again thanks! Ivanlp
Mar 17, 2009. 11:42 PMwonger18 says:
Hi, i have a question about your cross section. How can i print out a full size copy of it? it says it should by around 48 inches in length. im thinking about printing parts of it on many sheets of paper and then gluing them onto the templates. could you tell me how to get a full size?
Jan 14, 2009. 8:23 PMangelod0329 says:
thanks for the procedure in making a wood propeller. its a big help for my assignment...
Dec 3, 2008. 11:13 AMKohler says:
Great Instructable!! Now im feeling like building an Fokker Dr.1
Aug 4, 2008. 12:45 PMRotor-Head says:
Question.. I have a wood prop and the tip has a small piece out from a rock hit.. Other than that it's perfect. If I were to make a mold of the tip (from the other side) drill a few small holes in the damaged area and fill the holes and mold with an epoxy or something to rebuilt the tip... what would I use in terms of a filler material? Thanks
Nov 9, 2008. 11:19 PMbd5 says:
If I were you, I would dig out (even grind if necessary) the damaged area. Leave no loose or damaged wood in the nick. Get some high quality epoxy (do NOT use 5 minute epoxy), mix fiberglass (no longer than 1/8") into the nick. Use a metal file to carefully file away the excess epoxy/glass. Make sure you cover the epoxy with a good quality paint as epoxy can deteorate with light. Rebalance the propellor. Voila, you're done.
Aug 24, 2008. 12:11 PMdandumit says:
please tell me what routing bits did you used ?
Those : http://www.copycarver.com/copy_carver_burrs.htm Worth the money ?
May 1, 2008. 6:06 PMvulcano911 says:
Engineer: Please give us the blue prints. We will thank you forever.
Aug 4, 2008. 10:04 AMbudsiskos says:
what is the t/c?
1-40 of 84next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:AeroEngineer(AeroDyn Design)
I am an Aerospace Engineer. I love Technology, and Design.
