Introduction: Wood Ring
Picture of Wood Ring
This is my first ever instructable, so I know I should have included more pictures. I made this ring for my girlfriend for her birthday (she loved it)
Step 1: Supplies
Picture of Supplies
The stuff you need:
-wood, of course. I used a scrap piece of hardwood flooring.
-Drill
-Hole saw drill bit that is slightly bigger than what the outside diameter of the ring will be.
-Paddle bit or other drill bit to drill the inside of the ring where your finger will go.
- Dremel to sand and I also used a belt sander to sand some of it.
- Wood stain of any kind you want.
- woodburner to create designs like the heart I made on mine.
Step 2: Drilling.
I don't have pictures for this step, sorry. To drill the ring out, first drill a little with the hole saw, then switch to the drill bit for the center. Drill the center out completely, then switch back to hole saw bit and carefully drill it out entirely. now you basically have a rough, flat , sharp edged ring.
Step 3: Sanding and Detailing.
Picture of Sanding and Detailing.
In this step, use the dremel, sander/sandpaper to shape the ring into something more desirable. Also, in this step I used my woodburner to burn a heart shape into the wood, then I sanded down around the outside of the heart to make it stand out and be raised a little from the surface of the ring.
Step 4: Staining.
Picture of Staining.
After you are satisfied with how your ring is shaped, it's time to stain. Pour some stain into some type of container you can submerge the ring fully into the stain. leave it overnight, then return in the morning to take it out and allow it to dry.
Step 5: Finished Product!
Picture of Finished Product!
The ring is now finished for you to wear proudly, or to give to someone special.
Step 6:
legamin (author)2014-05-16
non-toxic stains that don't sweat transfer and that are hypoallergenic would be called for here.
I like the idea and wondered if you had thought of lathe turning these for safety and production? Also it would be cool to see one sanded really glossy as well...(my own little bewonderment to see how it would look..)
Great project! Stay safe and keep posting. Very cool idea!
gman2015 (author)legamin2014-05-16
The stain I used was the boiled linseed oil, which my father recommended because we have always used it on our leather baseball gloves. My girlfriend loved the ring so much that I haven't seen her without it in the three weeks since I gave it to her. As far as I can see, there are no allergies to it from her. I will put more research into stains the next time I do a piece of jewelry again though, thank you for showing me the importance.I do believe some people have used a lathe to turn rings similar to mine, but I currently do not have access to one. In my opinion though, I like the look of the ring being a little irregular and have more character. To make it too plain and perfect with a lathe would not have the same meaning to me. I have made a couple before where I added an additional step and coated the entire ring in polyurethane, which can then be polished and be very shiny. :)
About This Instructable
2,208views
32favorites
License:
More by gman2015:Wood RingWood Ring
Add instructable to:
