Wood Tic Tac Toe Board
5,366
93
8
Posted
Introduction: Wood Tic Tac Toe Board
This is a pretty easy project and makes a nice holiday gift. This version was made from a scrap piece of hardwood and a 5/8" dowel. As an extra touch, I added a compartment inside the board to store the pieces. The compartment panel is held on with magnets for a clean look.
The quick video shows how the compartment works.
Step 1: Tools/Materials
Tools:
  • Table saw
  • Router (optional)
  • Drill press
  • 1/2" and 5/8" drill bits
  • Sander
  • Ruler
  • Pencil
Materials:
  • Wood: 5"x5" x 1.25" thick
  • Oak dowel: 5/8" diameter x 7" long
  • Magnet: 0.437" diameter (x2)
  • Flat washer: 1/2" diameter (x4)
  • Super Glue
  • Wood stain or finishing oil
  • Paint (2 colors)
Step 2: Drawing
You will be building to this drawing.
Step 3: Base
Start by cutting the board to 5 inch square. My scrap piece was 1.25" thick but the design works for thicker wood.
Step 4: Grid
My table saw blade thickness is 1/8". Doing the math, I came out with the grid dimensions shown. Set your blade height to .125" and make the four passes.
Step 5: Mark Hole Locations
Mark the center of each square as shown. Use a punch to indent the wood.
Step 6: Drill Holes
I used a 5/8" Forstner bit for the holes. I chose to only go 1/4" into the board.
Step 7: Slot Cut
I used a router to cut the slot in the base. You could also do this cut by doing multiple passes over a table saw.
Step 8: Compartment Holes
I used the same 5/8" bit for these holes. It was a challenge to get the 3.25" depth (multiple setups). Use a 1/2" bit for the washer holes.
Step 9: Washers
Place metal slugs in the base holes. I used four, 1/2" diameter steel washers. Super glue was used for the attachment.
Step 10: Panel
The panel was taken from the cutoff portion of the original block of wood. Drill the magnet holes at the locations shown.
Step 11: Magnets
I used "Super Magnets" which, as the package says, are "extremely strong". After accidentally pinching my finger with them, I agree with the warnings :). Again, for attachment, I used super glue.
Step 12: Sand and Finish
Sand to break the corners. I used danish oil on the base and panel.
Step 13: Dowels
I used a band saw to cut the dowel pieces. You might have noticed that I show 5/8" holes and said to use 5/8" dowels in the materials list. This would be fine if you wanted an interference fit but the parts need to slide in and out of the compartment. Therefore, I sanded the dowel down by 1/32 of an inch before I made the cuts for the pieces. I would have done this using the drill press but the 5/8" dowel diameter was larger than my chuck allowed. Therefore, off to hand sanding :(.
Step 14: Painting
Holiday Colors! However, you can choose to paint the dowel pieces any color.
Step 15: Pictures - Panel Open
Here are a few pictures showing the panel removed.
Step 16: Pictures - Finished
I'm pretty happy with how it turned out. Thanks for viewing.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    7 Comments
    Great idea for hiding the pieces within the board.
    Great project with great instructions. Thanks!
    Such a simple, but excellent idea :)
    Thanks. This my first time using neodymium magnets. Those buggers were much stronger than I expected. I started paying attention after getting my fingers pinched for the second time!
