loading
Step 3: Bending the Veneer
Use the rubber cement to temporarily stick the top and bottom of the bracelet in place.
Measure how large the outside of the bracelet needs to be.  Add at least 1/4" to the width of the veneer and about an inch to the length.  You may want to add more if your wood seems prone to chipping.  Mine was very prone to chipping.
Put masking tape over the place you'll be cutting your veneer.  This helps stabilize it and reduces that chipping risk.  Mark out your cutting lines.  I cut mine with ordinary scissors, "cut a penny" scissors would have been better.  A utility knife would also work.  Once your piece is cut out gently remove the masking tape.
Soak the veneer in water.  I started with hot tap water and my veneer was completely limp in about 10 minutes.  Yours might take more effort - more time or heat should help.  Trees vary a lot so you'll have to use your best judgement here.
When the veneer is very pliable pull it out of the water, dry it a bit and then get ready to wrap it around the base.  Start with one end on the block of wood where the battery pack goes.  Clamp it down securely.  Then work the wood around the form, clamping as you go.  You want a neat, even curve.  Don't use any glue.  Clamp until you get to the end, leave the tail hanging out.  Let this dry thoroughly.
Once it's completely dry (we're talking hours or overnight), unclamp it, gently remove it from the form and set it somewhere safe.  It would be really easy to crush it right now, so up high, out of the way, where it won't fall is best.  Remove the top and bottom of the bracelet and scrape off any residual rubber cement.
<p>This looks awesome. I was actually looking at making some type of veneer art that the LEDs would shine through (Not for a bracelet). I think I could use this method for that. Thanks for the inspiration! : )</p>
good concept, and support it
Beautiful. And so it the project. ;)<br>Seems that the thickness of the electronics and wire could make construction a teeny bit finnicky. <br><br>As a possible improvement or two, please consider-<br>1. Thin copper foil tape instead of wire. This is sometimes found in craft stores which carry stained glass supplies.<br>2. SMD (surface mount device) LEDs for thinner electronics.<br><br>Hope this gets lots of people started with new creative ideas in &quot;flat&quot; construction!
That's just stunning, and a great task for someone with a few skills who wants to put them together in an elegant way. I love 'Ibles like this. Congratulations. :)
Thanks so much!
Gorgeous!
Thanks ChrysN!
Beautiful and well documented technique. The finished piece looks great.
Thank you!
wow, that looks great!
Thanks for the compliment AND the fastest comment ever!
About This Instructable
21,959views
104favorites
License:
Bio: Always making something....
More by technoplastique:Business Card Case With Covert Micro SD Compartment Modular Glowing Handwoven Textile Sierpiński Tetrahedron Fractal Kite
Add instructable to:
