This instructable covers basic wood whittling technique. You will learn a little bit about tools, wood, technique, and safety. Hopefully it will be enough to get you interested in learning!
Wood carving is not something you pick up over night; it requires a lot of patience and practice. What you will find, however, is that as you practice you will develop intuition that will allow you to tackle increasingly difficult problems on your own. It's an enjoyable and relaxing activity that I would recommend to anyone interested in learning a new skill.
Step 1: Tools
Let's start with tools;
Knife
You're going to need a knife. While you could conceivably use any kind of sharp knife, I highly recommend investing in something nice... I use the chip carving knife pictured here. High quality tools are going to be hand-made with tempered steel that will cut better and last longer than the low quality stuff. There are chip carving knives with different shapes that will make difficult cuts a little easier, although they aren't necessary for the beginner.
Sharpening Supplies
You'll be putting your knife/knives through a lot of stress and thus you will need to sharpen them. You can buy sharpening stones or you can use a combination of 600+ grit sandpaper and water or oil. Any piece of leather will work as a strop. I won't get into sharpening in this instructable, however there are plenty of resources out there for you to learn.
Step 2: Wood
So once you have your tools, you'll need something to carve. There are tons of different kinds of wood and they all carve differently. My recommendation (and the wood that I learned how to carve with) is basswood. It's cheap and you should be able to find it locally. The grain is small and the wood is soft.
However, it isn't crucial that you even know what kind of wood you have, so don't worry. Use what you have– that's part of the fun of carving wood.
Make sure the wood is dry; you'll have more control over it. Carving with wet wood adds a level of unpredictability, since as it dries it tends to warp and crack.
Step 3: Grain
Understanding grain is essential to wood carving... This is where your intuition will develop over time. While I will not go into the science behind the structure of wood, I will say that it grows in regular patterns that appear as grain. The orientation of the grain is going to determine how easily you can carve the wood. If you've ever had a splinter, you know what grain is and how its orientation matters.
You will want to start with straight-grain wood (which is exactly what it sounds like), where the grain runs in one direction. You can use the ends to determine what direction the grain runs in. The pictures below show you what to look for. Note that the grain can go down slightly... this will be important.
Basic vocabulary is as follows: when you are carving in the same direction as the grain, you are carving with the grain. If you are carving opposite the direction of the grain, you are carving against the grain. If you are carving perpendicular to the grain, you are carving across the grain.
Which way to carve:
You always want to carve with the grain or across the grain. The grain can also run up and down slightly, so make sure you are carving with the grain in the down direction. The next step contains pictures of carvings in each direction for your reference.
Step 4: Safety / Holding the Knife
Before we start, let's go over holding the knife correctly:
The picture below will show you how to hold the knife. When right-handed, my left hand is holding the piece of wood and my right hand is holding the knife. My left thumb is on the back of the blade and will be providing the cutting force. Never push the blade forward with your right hand; you will not be able to move the blade with precision.
Notice that my fingers are out of the path of the blade.
Don't be silly:
Never push hard on the blade. If it gets stuck (because you carved too deep into the wood or the grain orientation changed), stop and backtrack. If you try to force the blade, it could slip and cut your finger.
There's no need to go fast... Speed doesn't help you carve better. Take your time, at least until you feel comfortable carving.
Pay attention:
The sound and the feel of your cuts are important. You can hear the difference between carving with, against, and across the grain. This will be useful in developing intuition about the direction you are cutting in.
Step 5: Technique
So let's figure out what actually happens when you carve:
You'll be making a scooping motion. First, the knife has to dig into the surface of the wood a little bit. The knife must then be pushed through the wood; it's all about the angle! As you push through the wood, angle the knife up ever-so-slightly and you will have shaved off a bit of wood. With many types of wood, the shavings will curl; this is an indication that you are going in the right direction.
You should remove the wood in very thin layers; if you go too deep, you'll end up tearing out on the way back up.
The pictures below will show you what it looks like when you go with the grain, against the grain, and across the grain.
Also, your shavings are fairly informative. Check out the difference between shavings going against the grain and shavings going with the grain.
Step 6: Practice
A good way to learn knife control is to try keeping the knife at a fixed angle; see how long of a shaving you can make in one cut.
The more you carve, the more you will understand the grain. It's somewhat difficult to explain in a paragraph with a few pictures, but it will make sense as you experience it first-hand.
Start with gently curving objects that allow you some room to make mistakes. As you get better, add details regardless of the orientation of the grain; there is always a way to make the right cut.
Most important of all, have a good time! (and don't hurt yourself)
1-40 of 67Next »
SwanRonson says: Feb 20, 2012. 10:02 PM
That's a pretty nice kangaroo you carved, but you forgot that Kangaroos also have ears. Unless this piece was meant to not have ears then you nailed it. Good work, be well.
kevsauce in reply to SwanRonsonMar 3, 2012. 6:39 AM
its a dinosaur :|
Sonata85 in reply to kevsauceJan 6, 2013. 9:06 AM
LOL
Craftwright says: Jun 23, 2012. 3:02 PM
Hand carving tray a must have for all whittlers and wood carvers.
Check it out!
http://www.instructables.com/id/Carvers-Whittlers-Lap-Tray/
TYtheParacordGUY says: May 31, 2012. 11:03 PM
Im having a harder time understanding the "Grain". Im new and would like to try whittling as a new Hobby. I have many because i like to keep occupied and to try things new. Do you have any more tips for a beginner? -Tyler
Bodygard1117 says: Feb 15, 2010. 7:26 PM
that is cool i don't have the patients for wood but it looks like you do good job
SwanRonson in reply to Bodygard1117Feb 20, 2012. 9:59 PM
It doesn't make sense that you would have patients for wood. Unless you were a doctor for trees or something of that sort. Have a good day, be well.
SwanRonson says: Feb 20, 2012. 9:57 PM
Good Information regarding the Basswood. I found it locally and it's a pleasure to work with
littl3d00d says: Dec 10, 2011. 8:47 PM
ruffly how tall is this figure?
Ray from RI says: Dec 10, 2011. 11:17 AM
I like to carve myself I use a different set up in the form of a carving knife... However I am more interested in what you have carved. What kind of critter/creature are you carving?
Very cool!
staylor25 says: Oct 31, 2011. 1:43 PM
wow! thanks man i really neede those pointers you are really good at explaining to 5 stars young man
dirt action julian says: Oct 4, 2011. 11:16 PM
it looks preagnint
TYtheParacordGUY says: Sep 24, 2011. 11:14 AM
You should DEFINATELY make an instructable for the dinosaur!
kcls says: Feb 13, 2010. 6:46 PM
You should enter the dinosaur contest!
kylestetz (author) in reply to kclsFeb 14, 2010. 8:20 AM
i didn't even know about it! i most certainly will, thanks
TYtheParacordGUY in reply to kylestetzSep 22, 2011. 3:42 AM
what wood did you use to make the dinosaur???
mooner77 says: Aug 1, 2011. 2:07 AM
Com: of. Tony: Tony.
mooner77 says: Aug 1, 2011. 2:04 AM
Could you possibly use a x acto knife. And what tpe com wood would be the easiest Tony work for beginers. Thanx for any answrs d:
Wasagi says: Feb 21, 2010. 12:38 PM
 Excellent t Job! Sounds to me like that dinosaur would be a great wingman. Just go to bars with him, "Hey ladies, have you met my wooden dinosaur?"
I can see no downsides to that at all!
dombeef in reply to WasagiJun 23, 2011. 7:53 PM
If there was an award for the funniest comment, this would be in the top five
Metal Crave in reply to WasagiMar 1, 2010. 5:45 AM
 LOL!
Me Neither.
Aaron Hoffenberg says: Mar 18, 2010. 5:05 PM
You should post an instructable specifically for the Dinosaur
dombeef in reply to Aaron HoffenbergJun 23, 2011. 7:52 PM
I agree
corey_caffeine says: Jul 16, 2010. 7:56 PM
wisdom from my dad on how to carve a fish form wood "you take a block of wood and cut everything off that doesn't look lie a fish"
wenpherd in reply to corey_caffeineDec 8, 2010. 4:47 PM
Hehe, love that one.
LoneWolf says: Apr 2, 2010. 9:20 AM
Wow you are good at this!!!!!!
Nice Instructable, you explained it very well considering how hard of a subject it is to explain on paper.
chris1234416 says: Mar 29, 2010. 4:29 PM
Is it okay is i us a pocket knife/hunting knife.  Or will it be to complicated.  My blade is about 8cm long?
kylestetz (author) in reply to chris1234416Mar 29, 2010. 5:14 PM
if you sharpen it regularly it will probably work just fine.
brodyf says: Feb 15, 2010. 11:42 PM
I am interested in starting up this hobby.   The knife you use in the pictures has a straight blade and curved back.  I have been looking around for knives and have noticed a very wide variety in knives.  There are plenty with straight blades and some with curved blades. There are more blade lengths and shapes than I can count.
please give me some pointers on choosing a good knife or two for beginners.
Thanks.
kylestetz (author) in reply to brodyfFeb 17, 2010. 5:05 PM
All you need to get started is a straight blade. I honestly only have experience with straight blade knives; I would select a straight blade knife that is made of tempered steel, and one that looks like it will be comfortable in your hands. There is no 'right knife', and you can adapt to the tools you have.
As far as curved blades go, I really don't know how different the cut is. I would imagine they enable you to cut through more complicated grain patterns (an inward curving blade, for example, might allow more extreme angles when dealing with a change in orientation).
I really wouldn't worry too much about getting a specific knife; get a straight blade knife, and if you decide to take whittling seriously and push your skill, buy a different type of knife and experiment.
tankguy says: Feb 17, 2010. 7:05 AM
This is really cool. I've tried this for fun a few times but now I see a lot of mistakes I was making. Thanks!
john henry says: Feb 15, 2010. 7:05 PM
dinosaur? looked like a weasel to me at first but ok i get it now lol good job!!!
schroeder8 says: Feb 15, 2010. 2:42 AM
"It's cheap and you should be able to find it locally".
You know this internet thing is global, right? Could you possibly explain what properties of basswood make it good for carving and suggest alternatives?
blondeeboi in reply to schroeder8Feb 15, 2010. 3:12 PM
When he says find it locally he means at a nearby hardware store, not youre backyard
jfkendall in reply to schroeder8Feb 15, 2010. 12:35 PM
Hi Everybody and especially Schroeder8!
Basswood is a light colored,straight. even grained wood that is exceptionally easy to carve. In many parts of the world, it is called Linden. It is recommended as a beginning wood for most carvers. The grain is not pronounced and it will not conflict with the design of the carving. The structure of the wood is very consistent and that means that the cuts made find uniform resistance when the blade cuts through the wood. To understand the importance of this, think of pine. Pine has noticeable lines of harder, resinous wood that alternate with softer wood in between. When carving pine, the blade glides through the softer wood and has to be urged harder to go through the harder bits. Linden, or basswood, often has lengths that are free of knots which are another obstacle in the beginners carving experience.
As it was explained to me some time ago, any wood can be carved but some lend themselves to the process better than others. Basswood, pine, and butternut, all carve fairly easily and well. Butternut has a very noticeable grain [dark and light sections that look like lines] and so will compete with the overall lines of the design. This means that the carver must choose his or her project carefully.  Mahogany carves easily but along the grain and tends to leave a powdery deposit along with any chips. It is a sturdy wood but resists fine detail.
Hard woods, like walnut, hold details well but are harder to carve and darker so that the design often is harder to see. For woods like walnut or oak, gouges and chisels are often necessary to achieve what the artist is aiming at.
One interesting bit of information that seems to be counter intuitive is that your blade or tool must be sharper to carve soft woods than it needs to be to carve hard woods. Softer woods must be sliced through the grain and, if the tool is too dull, the grain simply gets crushed and detail is lost. Hard woods resist the cutting action of the tool and thus the tool slices through them more cleanly.
I do hope that this helps!
J.F.Kendall
lasersage in reply to schroeder8Feb 15, 2010. 8:18 AM
don't know about basswood but when I was into carving Lime was the wood to have. Very even and fine grain and also relatively soft to cut, but hard enough to wear well. Guy in our joinery had an epic eagle he'd carved from an old lump of lime. This is wittling (whitling? sp?) though so it may be different. We carved with fine chisels and gouges.
As for dry wood is best, I know wet wood will warp and crack as it dries but wood is just sooo easy to work when its green off the tree. Totally different though, I agree.
Thetis in reply to lasersageMar 26, 2012. 4:37 AM
Lime is the same as linden and basswood, so you are talking about the same wood, although the exact species might be different. All three are names for various trees of the Tilia genus. Check out Tilia on Wikipedia if you want to know more.
EmmettO in reply to lasersageFeb 15, 2010. 9:09 PM
 Now I'm curious. I'm no expert but I've done some carving and some projects, especially those that call for carving initially with an axe (my favorite part) call for using green wood.
Maybe it's just to make the initial rough work easier?
aeroengineer4 says: Feb 14, 2010. 2:24 PM
 Not to be picky, but instead of whittling it should be called carving. But great instructable!
static in reply to aeroengineer4Feb 15, 2010. 12:36 AM
 My thoughts as well. :) Whittling is the mindless making piles of shavings. One may end up with tool to scrape the mud off shoes once in away, rarely much more than that.
1-40 of 67Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
